Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refrigerator side is not cold therfore it seems to be pulling from the freezer because it wont freeze
  • Kelly  Smith
    Kelly Smith May 11, 2010
    i need more info
    Habit-Forming:
  • 171 Answers
The freezer heater needs replacing, it goes bad often, it's inside the freezer after you remove the racks remove the back panel the heater is located at the bottom of the condenser. it's about $50.00.
Posted on Dec 10, 2008
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
FREEZER SEEMS TO RAISE IN TEMP. AND ICE STARTS THAWING THEN STARTS FREEZING AGAIN. FRIDGE SIDE SEEMS NOT AS COLD ALSO.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Whirlpool ED2GHEXN Side by Side...
The freezer seems fine but the other side is not very cool.
I had the same problem w/mine, Found out it was the timer. There is a timer on most fridge's that turn on a defrost lamp inside your fridge. That is why all fridgs are frostless now. They still freeze up, but a lamp will defrost them automaticly. When the coils freeze up, they wont cool the fridge side & but will still cool the freezer side. generally the timer is where the controls are, behind the cover.
Mar 31, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Why does freezer get cold but not refrigerator side?
Check the freezer temp (available in most grocery and home improvement stores). The temp should be between 0-10 degrees F (not just barely below freezing).
You can also try to find a solution on www.repairclinic.com or click here.
Aug 13, 2009 | KitchenAid KSRG25FKSS Side by Side...
Refrigerator hardly cold freezer not freezing
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Jun 29, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
