Question about Olympus VN-2100PC Digital Voice Recorder
I have olympus digital voice recoder vn . 480 oc and windows vista, not working, not transfer and not identifiquet the olympus digital... in the list of CD windows vista is out I need of sofware for windows vista
  • Anonymous Jan 25, 2009
    ?????°?¹?²?µ???° ??????°?½?¾?²?»?µ?½??, ?½?¾ ???¾?¼?¿?Œ?Ž???µ?? ?½?µ ?²?¸?´?¸?? ?´?¸?????¾???¾?½. ?¥?¾??? ?¿???¾?³???°?¼?¼?° ??°?¼?° ?¿?¾ ??µ?±?µ ?°?????¸?²?½?°
  • agus_rabbit Mar 31, 2009
    Tuve muchos problemas para conseguir esta data, incluso llamé a Olympus en Argentina y me dijeron que todos los digital recorders ninguno era compatible con Vista.
    Muchas Gracias!!!!!
    Agustina
    I had the same problem, I also called Olympus in Argentina and the told me that any digital recorder is compatible for Vista.
    Many Thanks!!
    Agustina
    President:
  • 919 Answers
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window make sure the CD drive the digital wave player disk is located and is listed in the window
12. Check the "include subfolders" box.
13. Click Next
A security warning window will open,
14. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You
will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Posted on Dec 09, 2008
  • BabsOne Dec 09, 2008
    http://www.olympusamerica.com/files/Digi...
    http://olympusamerica.com/cpg_section/so...
    13. Click Next
Are there drivers available to download from a VN-480-PC to a MAC? Or any other way to transfer file format to work on a MAC? Thanks! Tony
Hi
the voice recorder should work instantly when plugged into the mac, it should show up as a removable stroage device, or a removable drive, like any other external hard drive or usb stick would on a mac.
you don't need a driver to transfer or listen to the recordings from the recorder on a mac.
Mar 03, 2011 | Olympus VN-480 PC Digital Voice Recorder
I recorded meeting minutes to my digital OLYMPUS VN-480 PC voice recorder and want to transfer the recording on it to my Dell Inspirion/1100 laptop. Could I transfer the audio from the headphone jack to...
yes, it is possible. You will connect the earphone jack from your voice recorder to Mic of your laptop. Then you will be needing a wave software on your laptop, download the wave software from the internet, open the wave file, then press play on your voice recorder and the minutes will be recorded into your laptop as a wave files.
But the easiest method of tranferring the minutes is by using the usb cable of your OLYMPUS VN-480 PC voice recorder. If you don't have it you can purchase it, then connect it from your OLYMPUS VN-480 PC voice recorder to the usb of your computer and it will be read like a flash drive.
After that, go to my computer and you will see a drive representing the OLYMPUS VN-480 PC voice recorder, open the drive and you will see your minutes, then simply create a folder on your computer, and copy, paste the minutes into the created folder. And the would be all.
God luck.
Oct 11, 2010 | Sony ICD-B200 Digital Voice Recorder
OLYMPUS VN-480PC RECOGNISE PROBLEMS WITH VISTA
Is this a new Vista system??? has the machine worked before on your computer.??? What is new, what has changed.???
The VN-480PC is compatable with Vista 32 Bit systems but NOT 64 Bit systems.
Verify by checking at www.olympusamerica.com instructions and software downloads are available there also.
Sep 24, 2010 | Olympus VN-480 PC Digital Voice Recorder
Digital voice recorder connection problem
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
13. Choose "install anyway" and the device will install.
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
I have olympus digital voice recoder vn . 480 oc and windows vista, not working, not transfer and not identifiquet the olympus digital... in the list of CD windows vista is out I need of sofware for...
12. Click Next
Mar 23, 2009 | Olympus VN-480 PC Digital Voice Recorder
Drivers for Olympus VN-4100PC Digital Voice Recorder.
12. Click Next
Mar 23, 2009 | Olympus VN-120 Digital Voice Recorder
File transfer VN-480PC doesn't work on notebook (Vista)
12. Click Next
Feb 19, 2009 | Olympus VN-480 PC Digital Voice Recorder
Olympus vn-2100pc
check out this link, i had exactly the same problem but this blogger has a working patch for the vn-2100pc and vista - works fine now!!
http://blog.ironguard.net/2007/06/olympus-vn-2100pc-and-windows-vista.html
Sep 13, 2007 | Olympus VN-2100PC Digital Voice Recorder
Olympus VN-2100PC Digital Voice Recorder Logo
847 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
