Question about Navman 3450 GPS Receiver
Navman se 3450 comm and baud settings
Hi Guys, If you can help me with this I would be forever grateful. I have a navman 3450 that I have had for 5 years. I am very much attatched to it.  Reciently I was in hospital and the device ran completely out of power and all the navman software was erased.  No big deal because I had all the softwate and I just reinstalled it.  The Problem is I dont remember the comm and baud settings for the gps status page.  I thoought  the comm was 2 but none of the combinations  seem to be working. I just keep getting "no gps data"  If you guys know how to fix this I will gladly pay if thats what it takes. Thank you, Jason Whistle PS Im unfamiliar with your service. If the guaranteed answer will def get this thing fixed I will gladly pay.
The correct baud rate etc settings are 57600, 8, N, 1 (ie 57600 baud, 8 bit, no parity, 1 stop bit). You can verify this and see other details of specifications at www.fingertech.co.uk/gps_navman_3450.html or www.pocketgpsworld.com/navman3450.php
The other thing you may have forgotten that you need is to install the Navman driver - unless you have done this, you will get a "card not recognised" error when you slide on the GPS sleeve. This driver, version 3.1.6, can be downloaded from the Navman website.
I don't think you need to set the COM port number as a number, rather you select the Navman driver and it automatically knows which COM port is associated. This is COM 6 on my setup, but might vary between devices?
The other thing that some GPS software requires is to know the "type of GPS receiver" - this is "Other NMEA"
Posted on Jan 05, 2009
Comunication error with 796d and computer.there's no serial port on my computer, so im using a rs-232 to usb. dosen't matter what usb port i use on computer, it still does not work. im using the...
  • Hi, I can help.
  • This happens a lot to people just setting up a scanner like this. Try these suggestions, I think you'll be up and running in no time.
  • You have to make sure the BAUD rate is set and make sure your PC control is turned on in your scanner. A BAUD is the rate per second data is sent.. A BAUD rate of 38400 (or what ever BAUD the software is at). I think parts 3,4 and 5 in the your scanner menu cover this. If you have the FIFO buffer set then remove it from your settings > control panel > comm ports. You will get the best results if you have that software read the bank before writing to it. Relabel your comm port settings if you need to as well ie. port 1, port 2 etc.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa,
Regards, Tony
Sep 21, 2011 | Uniden BC796D Base Scanner
Require a manual were can i get one from
Here is the manual for yo u.
http://www.navman.com/docs/manuals/navman-icn530-manual-en.pdf
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 18, 2010 | Navman iCN 530 GPS Receiver
My navman icn 320 keeps searching for gps signal
a few things to ensure
1) battery is fully charged
2) Thed correct BAUD rate and PORT are set ( see manual)
3) You are oiutside and there is a clear view of the sky.
Still failing? Then possible damaged SIIRF chip caused by starting engine while plugged into power socket
Please rate my help++++Thanks for using FIXYA
Jul 12, 2010 | Navman iCN 320 GPS Receiver
My navman f15 will not recieve signal anywhere
the reason your device does not receive any signal is because the baud rate and com port might be wrong. go to settings and fing GPS port, after entering choose auto choice so it can take the suitable gps port and baud rate
Feb 19, 2010 | GPS
System will not connect
check the comm cable between the computer and the device make sure that all settings are correct like address, baud rate, comm port connection, and their may be a setting that controls how long the device will attempt to connect this needs to be disabled.
Jun 06, 2009 | Lorex 4 Channel Business & Home Security...
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
Set up for navman se
I have a NAVMAN SE and I want to use it with my iPAQ 3630, also what sort of card do the NAVMAN take to store it data
Jan 17, 2008 | RIM BlackBerry Pearl 8100
Software for navman
i can help you with the smartST 2006. i own a navman n40i... in a few hours i will provide with a download link
Jan 17, 2008 | Navman NavPix N40i GPS Receiver
Navman 3450 GPS Receiver Logo
554 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
