Question about Pioneer Car Audio & Video
Pioneer M3000 Tape player not playing. Just goes into rewind, (or fast forward, not sure which,) as soon as I put the tape in.
    Sergeant:
  • 302 Answers
You need to get a head cleaner for your tape player and clean it.
Posted on Dec 08, 2008
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Video tapes only paly for about 2 seconds then stops
The heads need cleaning and/or the tapes are old and dirtying up the playing heads.
Run a wet tape head cleaner through an see if this improves.
May 23, 2009 | Televison & Video
Sylvania srd3900 error 2
Found no info in manual but cleaned tape heads and able to watch tapes. I don't know if this completely fixed problem because tape watched was not best quality.
Nov 30, 2008 | Sylvania SRD3900 DVD Player/VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Jul 26, 2007 | Panasonic PV-DV400 Mini DV Digital...
Car Audio & Video Logo
63 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
