Question about Dishwashers
Electrolux DX302SJ no power so can't start.
Reading other advice on the site I am guessing the circuit board has either come loose or burned out.
Is the circuit board located in the door? Can i access it easily to have a look?
Thanks Richard
This is a stupid website - how does this help anyone!
Posted on Mar 02, 2011
I have control panel off wiring and circuit board look fine still cf code
Thank you for your post, friend!
From the information you have provided your Electrolux refrigerator is displaying an error code of "CF". "CF" appears to be a communication failure this could be a possible issue with your control panel or wiring harness. I understand that you have the board off and everything looks good so this could need to be further evaluated by an authorized technician. Hopefully this is helpful. -Matt
Feb 12, 2015 | Electrolux Refrigerators
Electrolux range F14 fault
I understand that your Electrolux range is displaying an "E14" which is currently being displayed on your Electrolux range. Which means the display tail is missing or not connected. It could be a loose connector within the control panel. If not it could mean a replacement of the main control board or keypad.
I would recommend performing a reset on your appliance which you can do by disconnecting the power from your range. The best way to do that is by unplugging it or flipping the household circuit breaker for ten minutes. Hopefully this is helpful. -Matt
Oct 09, 2014 | Electrolux Kitchen Ranges
Electrolux (dishlex) DX302SJ dishwasher all lights flashing. When I press program and start buttons together code 1C flashes.
Take the kick panel off the bottom. There is a tech sheet in an envelope under the machine. IT will have everything that you need to do to troubleshoot the machine.
Dec 02, 2013 | Electrolux Dishwashers
Electrolux EX600 Dishwasher loosing power during wash cycle
Hi dan76n - Typically PF appears in the display when the dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad. If it proves to be ineffective, once again try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a cycle. If the problem continues, the dishwasher could possibly be experiencing a wiring failure or faulty board. At this point I will highly recommend connecting with a certified technician for a further diagnosis and to accurately assist with the repair(s).
Feb 26, 2013 | Electrolux Dishwashers
Wont finish wash and drain
I would turn off main power then open the controls looking for any burn parts on the power board before calling any one , how ld is this unit before yu spen too much get back to me
Dec 04, 2011 | Electrolux Dishwashers
My electrolux ewf 1030 get err 44 help me pls ?
E44 - It means "Door closure sensing circuit faulty".
Replace the circuit board and restart the diagnostic cycle to check further alarm condition.
When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5 on door interlock device, no.3 on electrical diagram) is powered by the triac (DOOR TY) on the PCB: after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed). The door interlock prevents aperture of the door while the appliance is in operation.
Microprocessor recognize closure position by sensing circuit connected to J2-1 on electronic board.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
electrolux-ewf-1030-get-qdylxco5jx0zjejqiwkxkzw5-1-0.jpg Dado
Aug 12, 2011 | Electrolux EW1200i Front Load Washer /...
Was turning on then off then back on now can not get to start at all even if i jump the low voltage line
Ensure filter is clean. Check switch near filter.
Try reset switch.
It could very likely be the circuit board/power module in the machine near the motor. It could also be a worn out motor. It's best to take to the nearest Aerus Electrolux store and let a service tech check it out.
For the store nearest you, follow instructions on below site.
http://www.aerushome.com/storelocator/
Nov 13, 2010 | Electrolux Central Vacuum
The circut board on my 6250 blew apart so i replaced it do i need to polarize it because i still have no voltage
I have seen this often, somtimes the circuit/s that power the board will burn out. Usually happens when using generator for powering large air comperssors or equipment that use capacitors. One circuit powers the board, some generators have a second winding for measuring voltage for regulator function. Service center will give you required ohm reading for both windings. For estimate only reading may be between 6 and 9 ohm. Also check that windings are not open or short to ground. Check polarity of brushes, you cannot swap wires to brushes. Circuit board should have come with instruction sheet for wiring. Good luck and post again if you have more questions.
Jul 02, 2010 | Coleman Powermate Premium Plus 6250W...
Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Apr 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
