Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer washes, drains but doesn't spin or rinse. open door to find wet, soapy clothes. Thanks
    Problem Solver:
  • 4 Answers
Read along in the threads/posts on the same topics. I posted a lengthy reply that has worked for me numerous times
Posted on Dec 12, 2008
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Epic washer doesn't spin fast. spins, but slowly. clothes coming out wet, very wet. it started after i washed a heavy wool sweater.
Check the filter, make sure rinse hold is not on, check the drain hose is not blocked, lastly check the brushes, remmember unplug first.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer is taking forever to go through rinse and spin. It ends with a code nd. Clothes are still wet and soapy.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Problem
replace the door latch wax motor and check the drain pump for obstructions.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
219 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
