Question about Broan-NuTone Broan Range Hoods Allure II Series - 36'' Range Hood - QS236
We have a steady hum coming from our Allue lll QS236 hood
How do you get fix it?
  • Anonymous Feb 01, 2009
    I have the same problem in my Venmar C270 30" range hood.
    How can I stop this humming?
  • gmcase735 Feb 01, 2009
    How can I stop this humming or is this normal?
  • 38 Answers
If it hums when the unit is off:
Its probally one of two transformers. Remove both screws holding bottom metal plate under filters. Locate both transformers, put your hand on each transformer to see if hum stops, if so just pry on it a bit until hum is isolated.
1-transformer back left, and one toward the front with yellow/blue wires coming out.
If it hums with unit on high speeds: its air leaking, it will take fairly long time to find.
Posted on Dec 15, 2008
  • Jean-Marc Pelletier Feb 08, 2009
    answer for gmcase735
    If the problem is only when the fan is off, its definetly the transformer. The problem is the weight of the transformer vs metal used to fabricate the whole hood.
    1.remove filters + 3-5 to five screws retaining the metal cover plate where the motor is.
    2.You will see a transformer to your right if you only have one motor, if you have two motors, the transformer should be located back left. Its a square metal casing with reflective vinyl sides and many wires coming out of it.
    3. Try prying the transformer a tad to either side(bend it) until sound is as quiet as possible.
  • zachandmj198
    zachandmj198 Apr 12, 2013
    worked for me
How to fix digital scale reading LLL
LLL probably indicates "Off-Level".Take batteries out / unplug power,re-apply power and make sure scale is Level....LLL also might indicate power is Low....make and model # ???
May 09, 2017 | Health & Beauty
G35 making humming noise from under hood
could be power steering pump,altenator or belt tensioners or idler pullys.
Nov 06, 2013 | 2004 Infiniti G35 Sport Coupe
I have a whirlpool quiet lll and it will fill with water but after that it just hums and does not cycle the water through to clean the dishes.... what should I do?
Are you shure that it is a dishwasher ??, because only a cloth washer "fills with water". Could you give the model #.
Sep 01, 2011 | Whirlpool Dishwashers
Weather dropped to around 20 degrees F, the washer fluid is empty. the car is off, key out of the ignition, but there is a steady humming noise coming from under the hood.
Hi there is a very small fuel powered webasto heater under the bonnet that could be making the noise that is circulating and heating the engine coolant to ensure a first time start and quick interior heater response this will operate at a pre set minimum temperature or you can set it to come on
at a higher temp if you like your heater toasty on a not so cold day
however this does run off the fuel in your tank
Dec 14, 2010 | 2005 BMW X5
Hotpoint side by side refrige problem
Sounds like the gear jammed , replace the ice maker for a fix.
Apr 10, 2009 | Hotpoint HSS25GFP Side by Side...
42" Allure II Broan Range Hood I put a new bulb to replace
Get two new bulbs and install them. These bulbs are exposed to a lot of heat above the stove and the filaments get brittle. I suspect that the filament on the bulb that still worked broke when you were screwing it out or back in. good luck. please rate my answer. thanks noreen.
Feb 03, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Can not get halogen bulb out of my kennmore elite range hood
You will have to do the following steps.
1. remove filters
2. Unscrew 2 screws retaining metal plate under the filters.
3. Now you must remove the whole light panel. 5 screws in all, three under the front lip and two at both back ends of the same panel.
4.You now unhook the light wires (plastic connector with two wires)
Now you have the whole pnale in your hands. Unclip the socket of "problem side" and unscrew the socket from the bulb. Re-do steps 4.3.2.1
Jan 27, 2009 | Broan-NuTone Broan Range Hoods Allure II...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Kitchen Ranges Logo
1,372 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
