Question about Toys
How do you raise the karaoke 5 ft santa to full height?
We don't know how to raise him up. He is currently compacted down because he was in storage
  • 1 more comment
  • cujones Dec 21, 2008
    where is the release located for the karoke santa. I checked and did not see one above the feet.
  • Anonymous Dec 24, 2008
    I HAVE THE SANTA AND HE IS NOT POPPING UP WHAT CAN I DO ? I CANT FIND THE RELEASE ON THE MAIN SHAFT ? WHERE IS IT -
    I AM LOOKING EVERYWHERE AND CAN NOT FIND IT ? HE IS NOT STANDING LIKE HE SHOULD
  • REDNECK BABY Dec 24, 2008
    I CAN NOT FIND THE MAIN SHAFT TO RELEASE IT AND MY SANTA WILL NOT COME UP CAN YOU HELP ME ANYONE ???
  • 18 Answers
On the one we have at work, there is a release on the main shaft above the feet so that he can stand tall, it then clicks into position so it doesn't fall. Hope this helps.
Posted on Dec 08, 2008
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
Dec 01, 2015 | Toys
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
How do I raise the ride height on the front of a 2008 Jaguar XJ8
Raise the ride height? It looks like your front air shock absorbers have failed... of could be the air line manifold near the metal air storage tank.
Oct 02, 2014 | 2008 Jaguar XJ8
How do you calculate cubic feet?
You calculate a volume. If all the lengths, radii, heights are in feet the resulting volume is in cubic feet.
Example: Right rectangular prism with L=5 ft, W= 3 ft, height =1.5 ft
Volume =(5 ft)*(3 ft)*(1.5 ft)= (5*3*1.5) (ft*ft*ft)=22.5 ft^3
Nov 19, 2013 | Office Equipment & Supplies
How to raise the seat height, I am 6'2 tall
Best way would be to take it to a shop let them turn up the dampers and then turn up the rear shock as well, 6'2 you will need at lest 5 more inches of height to feel comfy.
Jul 13, 2013 | 2004 Triumph America
I do not know how to pull the top part of a 5 foot animated santa from the bottom part.my wife always did it and she died and i don't have the instructions..
It is suposed to pop up once you press on its shoulders. Once you press them both down you will hear two clicks and release and it will pop up. Mine was jammed and when I pressed it down on the shoulders only one side would click, the other side would not click so Santa did not pop up to full size.
It was jammed on the white area of the stocking, the material got tucked inside the click mechinism prevent it from making proper contact. To fix it I simply pulled the white stocking material up (as if you are going to roll the pant leg up) and then when I pushed the shoulders down after that it opened up just like it should!
Dec 08, 2010 | Gemmy Life-Sized Animated Santa
I need to raise the handlebar height on my 26" bike.
On the neck, the bolt would be at the top, dead center, screwed down inside the neck. Loosen it about 5 full revolutions. Then take a hammer and tap it back down. Lift the handlebar to desired height, and hold it there 'til tight. Also while it's a little loose turn it clockwise/counter clockwise, to make the bar straight (while holding the front wheel) before fully tightening. Then your done! Glad to help. Best wishes to you.
Jan 18, 2009 | Huffy Cycling
Toys Logo
267 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
