Question about HP Office Equipment & Supplies
My printer is having a problem feeding the paper to print
  • 453 Answers
Try wiping the rubber rollers with rubbing alcohol
Posted on Dec 08, 2008
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
Printing
In the print menu, you will see a Settings or Properties where you can set your paper feed as manual or auto. It looks like you have set it up for manual feed. so you have to go back to that settings and change the paper feed to auto.
Hope this will work for you.
Good luck
luciana44
May 04, 2010 | Brother MFC-6890CDW Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
SAME PROBLEM LEXMARK X2350 STARTS FEED PAPER AND PRINTER HEAD MOVES AS PRINTING BUT WILL NOT FEED PAPER WHILE PRINTING? ARE THERE 2 FEEDERS IN THIS PRINTER? HOW TO FIX?
transfer roller that starts the paper and feed that feed the paper. have you had a paper jam and torn a piece of paper off inside the feed mech? i dont remember if this one feeds off the motor or a belt. either way you would have to disasemble the printer to determine where the problem lies. might be more econimical to replace the printer.
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Dec 09, 2007 | HP DeskJet 820Cse Printer
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
