Question about Sony STR-DE845 Receiver
Sony str-de635 everything works except for display
  • Newb-e Dec 31, 2008
    i can hook it up to the tv but when i turn the DVD player on I can only hear Audio.
  • 336 Answers
It may need soldering of the display, could also be a bad resistor or transistor in the power supply.
Posted on Jan 14, 2009
Where can I get Manual for Sony STR-DE635
Sony has the user manual for the STR-DE635 here: https://docs.sony.com/release/STRDE635.PDF .
I hope this helps.
Feb 04, 2018 | Sony Audio Players & Recorders
WHEN TO TURN SONY STR-DE635 ON AND NO AUDIO OUPUT
Maybe the Preamp driver IC, looks like a car audio ic on the main board.
Often with age the heat generated by the ic will destroy the solder.Makes it look like lava rock in bar-b-que grill. Which
causes an open circuit in the preamp driver to the audio power
stage.
Simply resolder them, most often restores audio. Should have
a bottom removalble cover.
If not, a fuse normally blows if ic or channel is shorted. Check if
display will say Power off, Protect, etc. That means there is a problem with a channel.
Most Sony receivers use darlington transistors, they short easily !!
I am an old school component level service tech, I think I do have a schematic for this model and many others.
Jan 12, 2012 | Sony STR-DE635 Receiver
Hi, i have problem with my Sony STR-DG820, front display is broken, is any chance get new one from somwhere, everything is working except of this thanks
I had a broken knob on my Receiver and was able to find one from a printer place. I am pretty sure he can find the part you need.
perfectprinterparts@gmail.com
Michael
Jan 16, 2011 | Sony STR-DG820 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
Led display goes dead
I suspect intermittent 31V supply, filament supply or bad connections on fluorescent display.
Check Q801 31V reg , R802, zener on base of Q801 located on DC board. Inspect all boards for bad solder joints, reflow and tighten pcb grounding screws.
Oct 23, 2007 | Sony STR-DE635 Receiver
Sony STR-DE845 Receiver Logo
172 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
