The fan or the engine sound really loud but once the ****** goes through the gears the sound goes back to normal
SOURCE: Engine sounds like its working hard
if it does it then stops then sounds like your fan clutch working and is normal
SOURCE: fan loose , anti-freeze dripping
there is a weap hole in the bottom of the pump if it is leaking from that it is the pump they will make noise when they go out also
SOURCE: 02 Durango: loud engine/exhaust sound
That noise is probably the air injection system which is part of the emmision system. When it is making that noise, open the hood and determine where it is coming from, note if it is a mechanical sound, etc. The air injection if equiped would sound almost like forced air scaping somewhat like an exhaust leak, but less intense.
SOURCE: 2001 dodge durango 4 wheel drive not working loud knocking
You need to check the cv joints in the front end or the u joints in the front drive shaft.If none of the above then the problem is internal in the front diff.
SOURCE: 200 Dodge Durango Clutch Fan
i have 2000 dodge durango and i need to replace da fan but cant seem to take it off any ideas?
