Question about Sony Handycam CCD-TRV67 Camcorder
Sony camcorder stopped working
I have a Sony Handycam CCD-TRV67 Hi-8 Analog Camcorder that has just recently stopped working with the battery. It works fine when plugged in to an AC source. I've had it for about 7 yrs and it has worked perfectly - never a problem. Now before you think, "duh, did you check the battery", I should add that I have 2 lithium batteries that I use interchangably and both stopped holding a charge at the same time. That just seems like too much of a coincidence. They appear to be charging (while in the camcorder) when I plug the camcorder into an AC source, but as soon as I remove the plug and turn on the camcorder, it just makes several "bling-bling" noises and dies. Any ideas?
  • mbizari Nov 04, 2007
    the same problem. I found out that the problem is that the charger of Camera is dead. it sees a factory problem of this kind of camcorder, that the charger dead after 5 to 7 year of work.
    my camera is DCR-TRV17, but the problem is exactly just like what you describe.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 575 Answers
Batteries have croaked
Posted on Apr 09, 2017
    Top Expert:
  • Sony Master
  • 12,962 Answers
Your batteries have croaked and need to be replaced.
Posted on Mar 31, 2017
  • 473 Answers
SOURCE: Can a lithium ion battery be overcharged?
Here's a small FAQ I found: 1) My lithium ion battery is the SONY NP-FP70 Battery Pack. Does the fact that the battery is called a battery pack mean that it has built in circuitry to prevent an overcharge? No. I write with some authority since I've dissected too many and there is no such circuit in the battery. From a system perspective it doesn't belong there. 2) Is there any way of knowing if my SONY BC-TRP charger has the circuitry for preventing an overcharge? You'll have to ask, but the key clues are: a. The documention tells you to not leave it plugged in overnight. b. The battery gets too hot and melts the plastic. 3) If I charge my battery in my camcorder (SONY DCR-HC40), can I assume it has the built in circuitry to prevent an overcharge? a. One can't assume anything. b. But from what I read on that model, you plug it in and forget about it. To do that, it would have a proper charge circuit.
Posted on Sep 13, 2005
JoeO700
  • 80 Answers
SOURCE: Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 15, 2007
welcomejee
  • 10594 Answers
SOURCE: Handycam says C:31:22
error 31:22 means camera mechanism has error in take-up reel section and micro processor isn't receiving reel signal so it shuts down playback/ record function immediately. look into take-up reel section of mechanism.
Posted on Sep 12, 2008
jyackle5
  • 8197 Answers
SOURCE: a cable connector for ccd-trv67 to a usb port of a PC
Look at the links bellow.
http://shop.ebay.com/items/s%20video%20to%20usb?_dmd=1&_sop=12
http://www.usbvideoadapter.com/Video_Audio_Adapter/audio_index.htm
Good luck and please rate FixYa! for free awnser
Posted on Apr 07, 2009
zohail
  • 1223 Answers
SOURCE: Sony Handycam CCD-TRV107E Hi-8 Analog Camcorder
CCD Failure !
but u are entitled for free repairs from Sony just call them it is a known problem
http://www.sony-asia.com/support/announcement/45536/product/ccd-trv107e
pls rate me Fixya for help
Posted on Apr 20, 2009
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
My ccd-trv67 camcorder only comes on and works when i put it on charge otherwise it doesn't work how can i fix this?
Make sure that the battery is connected right and if it still has a problem try getting a new battery. After a while batteries stop holding their charge and need replacing. batteries can be found online or around 20$.
Aug 23, 2011 | Sony Handycam CCD-TRV67 Camcorder
Sony Handycam CCD-TR818 Hi-8 Analog Camcorder: How can I transfer my vedios to my laptop.? Plz help.
You require an A-D Converter. Analogue to Digital Converter box.
Note: Many mini DV cameras can act as a Converter if they have analogue inputs.
Apr 15, 2011 | Sony Handycam CCD-TR818 Camcorder
I have sony ccd-trv76e handycam ,i want to transfer all movies i have recorded to my pc how can i do this.
Dear Freind ,
I am also using a good & nice product of Sony TRV 76E analog camcorder .I had converted all my hi8 videos to MPEG 4 format .
I am using a PC with Murcury TV capture card .In camera one AV out jack is available which is connected to murcury TV capture card .First it will recored in AVI format then you have to use one good video editing tool to edit & desird video format . I think your problem has resolved.
Thanks
Srinivas Nowduri
Hyderabad India
E Mail Id : snowduri@yahoo.com
Nov 11, 2010 | Sony Handycam CCD-TRV67 Camcorder
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
Where is usb connecttion for a CCR-TRV37
CCD-TRV37 is analog Video-8 camcorder and has no USB port / connection. USB port is available only in digital camcorders.
Jun 07, 2009 | Sony Handycam CCD-TRV37 Camcorder
I have a Sony Video8 Handycam CCD TRV211.
If you are asking about CCD-TRV211 camcorder?
CCD-TRV211 is analog Video-8 camcorder so its movie data is not digital and can not be connected directly with computer via USB port.
Best and easiest was is to connect camera with DVD Recorder and burn DVD, this will convert analog movie file into digital data and you can copy it to hard disk of computer.
Mar 31, 2009 | Sony Handycam CCD-TRV308 Camcorder
Transfer of video.
If model number is correct i.e CCD-TRV67, means its analog camera and can't not be connected directly ( USB ) with PC. Suggestion is to record movie on DVD by any DVD-Recorder to get analog signal in digital format. Now you can transfer it in PC.
Hope this info will help you and if you find it helpful, give vote as fixya.
Aug 18, 2008 | Sony Handycam CCD-TRV67 Camcorder
No power and does not indicate charging Problem
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam CCD-TRV67 Camcorder Logo
60 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
