Question about Abit RX600PRO-GURU RADEON X600 PRO GURU, (256 MB) Graphic Card
Rpm's and graphics
Recently my video card has been degrading in performance. For example, there was a certain computer animated movie that was released a while back. It is extrememly well detailed and can only be run on a pretty good graphics card to run smoothly. It used to on my CPU, but now it's aall choppy. I changed the amount of virtual memory, erased a buttload of stuff off that particular partition and quite a few other things befor I dicided to open the OC Guru. It says that the fan on my Abit RX600PRO-GURU card is at 0 rpms and is giving a warning that says core fan abnormal. It isn't dusty at all and free spins when I do it myself, and I don't feel any air coming out from it when my cpu is running. Any suggestions (seeing as trying to adjust fan speed isn't working). Maybe I missed something.
  • 624 Answers
Hi Naida, A while back I had a computer that was having all kinds of video issues after it had been on for a little bit. I pulled the video card out and like you was able to free spin the fan and didn?t see any dust worth mentioning. Also like you I ran the computer with the case open to verify the fan was actually spinning but noticed there really wasn?t much air being moved. I removed the fan from the card and to my surprise found that the cards heatsink directly underneath the center of the fan was blocked with a solid ball of dust I couldn't see before. Cleaned that out, reassembled and I was good to go. If that doesn?t do it you might consider replacing the card fan. They?re small, cheap and run full board on gaming machines. Since you?ve gotten some messages indicting your software detects 0 rpm it would be a logical and cheap thing to try. Let us know if this works and please don?t forget to rate this post.
Posted on Feb 21, 2007
How to play games with standard vga's
You might not be able to play certain games that have animation because they use a lot of grahics and you will need to update the graphics card drivers or install more computer ram
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers if your computer came with a motherboard disc the drivers could be on it or you might try these http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance Hope this helps.
Jan 08, 2013 | Computers & Internet
Which graphic card is suitable for my compaq presario sg1138il pc?
The type of graphics card you need depends upon the programs you are using.
For example if you only use your computer for simple wprd processing, e-mails etc. then you only need a low end graphics card.
If you have a high performance computer and you play graphics intensive video games that renders realistic images, then you need a high end graphics card and these cards will have large video RAM (memory).
There are a large range of graphics cards on the market, I suggest you Google search for graphics cards that matches your programs and application requirements.
If your model computer has an AGP expansion slot, then make sure the graphics cards are AGP cards.
Sep 03, 2010 | Compaq Computers & Internet
When i go to play any of my games on my desktop pc my computer freezes and goes to a blue screen at the same point every time even though my computer meets all the specifications required, i think that i...
This one really depends on the game or application your trying to use. Bioware for example most recently had an issue with Mass Effect 2 in which the game did not work well on non-dual processors to spite system specifications. The issue had to do with the movies, not the the rendered scenes. Ironically, new compression standards have made some video more intensive on lower end processors than fully 3D rendered scenes. If the problem was heating or damage to the card, you would crash after a certain amount of use, not at a certain point in the game. If you think it is the card, you can turn everything down to the lowest setting and see if the issue goes away. But I'm betting it won't. I would check the other components...make sure your system RAM is good, look for patches or forum complaints about the game your playing, and close out anything like Skype, Steam, messenger clients, etc. that your not using.
Mar 08, 2010 | ATI RADEON 9550 Graphic Card
What video card would be compatable with a insignia computer model d300?
I would recommend any of the Nvidia or ATI video cards that come in the PCI format. Your computer only has PCI slots. These are the older slot types, so your options will be limited for brand new cards, but there's still plenty out there. As long as the slot type is PCI and the chipset is a major manufacturer, it should work with no problem. Do NOT get any video card that says "PCI Express" or "PCI-X" - they won't fit.
Jul 18, 2009 | Insignia Computers & Internet
I hav a nvidia 8400gs graphics card how can i increase its size 1. by sharing it with hard disk 2.by sharing it with ram 3.what are the effects of this procedure?
upgrading your video card. There are probably only two basic reasons to upgrade a video card: 1. Your current card has poor performance.or You just "want" faster video performance.
If you think your current video card is performing poorly, there are a couple of things you should do prior to upgrading your video card. The first thing your should do is give your computer a "tune-up". This involves things like running Defrag, Scandisk, virus checkers etc. (for further explanation of tune-up procedures, .
Once you are certain that your computer is performing properly, and your computer is still experiencing slowdowns in video intensive programs, like games or graphic design programs, then the second thing you may need to do is upgrade your computer's main system memory. Inadequate amounts of system RAM will choke your computer's performance. That's why I recommend all newer computers have at least 512 MB of system RAM.
Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
When i try vidio clips the sound and the vidio ,stops few seconds and starts again and does it again and again .
it may be that your graphic card is not powerful enough to handle 3D and animation programs like watching video clips on the internet, movies on your computer etc.
try upgrading your graphic card to a more powerful ones like ATI and Nvidia graphics, both manufacture good graphics card.
If you want to upgrade, consider the following:
your system slot type: PCI, AGP, or PCI-express. read your PC manual for the correct card type.
Purchase the correct video card type based on your system slot type.
also look for graphic cards with more memory .
Please rate this solution. Thanks
Dec 28, 2008 | Computers & Internet
Graphics card causing system to shut down?
Please go into the BIOS of the system and Set the BIOS as default
  1. Restart your computer.
  2. When the computer first starts, it performs the power-on self test (POST). This test checks that all connected devices are functioning. As part of the POST, the memory is checked. During the memory test, a message will appear that tells you how to access the BIOS. For example, you may see the following message or a similar message that explains how to start the BIOS setup: PRESS DEL TO ENTER SETUPIn this example, you must press the DEL key immediately after the memory test is finished to start the setup process. You may have to press the key several times to make sure that you access the BIOS setup.
    Tip There are other keys that may provide access to the BIOS. They include the following:
    • F1
    • F2
    • F10
    • CTRL+ENTER
    • ALT+ENTER
    • CTRL+ALT+ESC
    • CTRL+ALT+INSERT
    If you are not sure how to access the BIOS setup, see the user manual for your computer's motherboard.
  3. Look for the Set BIOS as Default settings. You can usually use the arrow keys to move through the menus and settings.
Do that and then try to
Regards
Dec 22, 2008 | Power Color ATI RADEON 9200 256M DDR...
GeForce FX5500 Graphics Card - Problem with TV out on .avi files in Windows Media player
this is probably(not certainly) bue to wrong confihuration
set ur tv system (pal mnts 3 4 ) and of 3d card to identical and it may solve problem
worked for me under pal system on both devices
Sep 23, 2008 | XFX GeForce FX 5500 Graphic Card
ATI RADEON X1650 -- Video degrades during vewing - becomes blotchy and red
welcome to fixya
the video card might not be getting enough power you should have a 500w power supply or higher with that video card if you have this already might want to see if you can download any new drivers for the video card
i hope this helps out have a good day
Jul 18, 2008 | ATI RADEON X1650 Graphic Card
Abit RX600PRO-GURU RADEON X600 PRO GURU, (256 MB) Graphic Card Logo
62 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
