Question about Sharp LC-26DA5U 26 in. HD-Ready LCD Television
How to connect my Sharp LC-26DA5U to my computer as a monitor
I try to connect my sharp LC-26DA5u to my toshiba laptop libretto U105 , I get a cable DB15 to DB9 and do not have any respond on the tv, any suggestions.
  • 1 more comment
  • Fernando Mayorca Feb 24, 2007
    Thansk for your answer but unfortunatally did not help much , this model of sharp LCD tv only have and imput of r232 or HDIM ,do not have an 15-pin connection, anyway, ¿ it is any chance to make the 15 pin conection on the laptop to HIDM to the TV? or 15 pin on the laptop to composite RCA or Video RCA?
    My laptop(Toshiba libretto U105) also use a external conection to monitor that they call mini-RGB that look exactly as HIDM do you think it will work with a HDIM to HDIM cable.
  • Anonymous Apr 18, 2009
    this tv was not fitted for pc input. ...but i am running a dvi to hdmi cable from my tower. Works great if your vid. card can anti-scale and adjust to the off centering of your desktop image.
  • Anonymous Mar 17, 2014
    when i connect my laptop to our 42 inch sharp lc tv with hdmi cable my powerpoint presintation will play on laptop but tv stays on desktop screen
    Scholar:
  • 135 Answers
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Posted on Feb 21, 2007
  • Joshua Muskovitz
    Joshua Muskovitz Feb 25, 2007
    I was unable to find a manual for your exact TV model, but I had found a close one, and my earlier solution was based on that.
    If the only video output from your laptop is VGA (via the mini VGA port), and if you don't have a VGA (or DVI-I or DVI-A) input on the TV, then you can't directly connect these together.
    The mini VGA port is not the same as HDMI. VGA is an analog connection, HDMI is digital. VGA can be converted to the analog version of DVI, which you can use if your TV has a compatible input.
    Another possible solution is a VGA-to-Component converter. This will convert your VGA output to YPbPr, but will require you to configure your laptop to put out a 480p, 720p, or 1080i signal (depending on what your TV accepts). This link http://www.smarthome.com/777060.html) is one example of this, but isn't the cheapest one out there (just the first one I found).
Need the stand for Sharp Aquos model #: LC-26DA5U
Contact the authorized dealer for Sharp. You can try the Ebay; and Amazon, online store too. They sell universal stands both for wall and table.
25785650-jl5uyyoghsh2bivuwqwtbh44-2-0.jpgEBAY 25785650-jl5uyyoghsh2bivuwqwtbh44-2-2.jpgAMAZON http://electronicshelponline.blogspot.com/
Jul 16, 2015 | Sharp Televison & Video
SHARP LC- 26sv490u And trying to connect a Toshiba
Sounds like a preamp circuit might be blown on the Sharp.
Nov 17, 2017 | Audio Players & Recorders
I bought a x2gen mg5r4 monitor at the goodwill I've got a power adapter that supplies the proper voltage & amperage to the monitor. It powers up just fine, but when plugged into the computer it (the
If the monitor indicates "No Sync" Make sure your video cable is a high density DB15 end. If it is only 9 pins, you have a DB9 cable or connection. Also make sure the video you have it attached to is enabled and is also a high density DB15. (it will have 3 rows off pins. The DB9 will have 2 rows)
If those are okay it may be broken wire in the cable or on the monitor's DB15 connector/connection.
Dec 18, 2011 | Computers & Internet
Can I hook up my Toshiba laptop to my Sharp Aqous TV, if so what connections do I need, ?S-video? I have an SGA connection on my laptop but not on the TV?
If this is the exact model Sharp Aquos television you have then you would have to have a laptop that has hdmi or dvi. You can try S Video on a laptop but the laptop's resolution would have to be so low that most laptops cannot accommodate this. You're right; this television does not have a VGA (RGB cable) input.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I WANT TO USE MY SHARP REMOTE TO OPERATE MY SHARP TVT, DVD AND DIRECTV. I DON'T KNOW HOW TO PROGRAM IT. THE TV MODEL # LC-26DA5U
Go to the Remote control Manufacturers website and get the instructions for the remote control. Then you need the codes for each of the items you are going to program in. You can get some of the Directv functions on universal remotes, but if it's a DIRECTV with DVR then the rewind functions, etc. may not work. Good luck!
Oct 08, 2010 | Sharp Remote Control
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Monitor looks shattered when turned on
if it only looks like that when it's in windows, then it could be a joke wallpaper someone put on it, otherwise it is indeed broken. Tilt it down and shine a bright light on it, if you see what looks like an exploded pen inside it, or cracks, it's done.
Apr 26, 2010 | Toshiba Libretto U105 (PLU10U00901D) PC...
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Connecting pc
Did you change the input on your tv to the corresponding input that your RGB cable is connected to?
Mar 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
HDMI connection problem
Your TV doesn't like your laptop I guess.
There should be 2 reset buttons behind your TV.
Press the reset button first.
If that doesn't work, try the system reset button next.
If that doesn't work, you'll have to call 1-800-BE-SHARP to help you with the possible software problem with the TV
Good Luck
Feb 12, 2009 | Sharp Aquos LC-32D40U Television
Sharp LC-26DA5U 26 in. HD-Ready LCD Television Logo
1,403 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
