Question about Refrigerators
Have an older kenmore freezer model 1068253080.....found out that it shut off during the night....light come on but no compressor action....was wondering what the problem could be.....had it turned off for about a year....just started to use it again....thanks
  • ak2679 Dec 08, 2008
    I appreciate your quick response...it is more than 10 yeras old...and yea was already thinking of just replacing it...thanks a lot sir
  • 750 Answers
Hello and welcome,
if it's old and sat off and not used for a year. Then there may be a tiny crack in a seal that allowed the freon to leak out over time. Or it may not be tiny!
If the repair cost half the price of a new unit it is not worth repairing. if the unit is ten years old or more then a new one will be MUCH cheaper!!
to operate!!!!!!!!
Thank You for using Fixya.
Please remember to leave a solved rating before you sign off!
Huum
Posted on Dec 08, 2008
Sear chest freezer stop working model#2539139180
The compressor probably shut off on thermal overload. This protects the compressor from burning up. What has happened is that a capacitor or evaporator has gone bad or it could be low on freon. Have someone take a look at it. However, if it is older than 8-10 years old, consider replacing it. This could be the beginning of the end.
Feb 02, 2013 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Model 5920991 kenmore side by side unit quit
Pull the fridge out and remove the bottem panel .find the compressor it is a black round unit.listen to see if the compressor is running should make a hummming sound if you put your ear by it.If it is not running check the starter relay. TO check it unplug fridge remove relay it is located on the side of the compressor with 2 or 3 wires running to it. remove it and shake it if it rattles or if there are burnt spots on it it needs to be replaced.Hope this helps. if so give us a4 thumbs up.THANKS
Mar 02, 2011 | Kenmore Side by Side Refrigerator
My Whirlpool bottom-freezer, french-door refrigerator is 3 years old. All the lights work fine, as does the ice-maker, and the main compartment cools as it should. The problem is: the compressor motor...
Newer model refrigerators run a lot more than older ones but you could have leaks around gaskets, check freezer compartment and see if there ice buildup around door if so let this defrost by turning off if possible. The defrost circuit should take care of this but sometimes in very humid weather it does not.
Aug 02, 2017 | Whirlpool GI5FSAXV Bottom Freezer French...
My light stayed on and melted the fixture. What would have caused this? I noticed that it is a problem with Sears Model 795.7757960
Hi, faulty or broken door (light) switch, whenever you shut ref. door light switches off, locate door switch and press/release (check) , if your light switch are o/k, always make sure ref. door are closed all the way, just a little space in door,(during night time) could keep light on. that could cause your fixture cover to melt. good luck.
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Nov 21, 2008 | Ovens
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 596.755 23400 problem with freezer
You can try to replace the relay and overload but on this model usually the compressors go bad. Call sears to check the warranty. The compressor should have a five year warranty.
May 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
