Question about Brother IntelliFax-2820 Laser Fax
How to set up 2 fax machines on 1 dedicated line
I have 2 Brother IntelliFax machines that are both on the same dedicated line. I would like to set them up so that one machine can send & receive and the other only send. Any ideas?
    New Friend:
    Problem Solver:
  • 19 Answers
Set the rx fax to ans on the lowest # of rings and fax mode..Set the tx fax on tel mode..
Posted on Apr 07, 2007
My intellifax 775 has a code TAD...what does this mean? Will not receive faxes
This means your receive mode is set to TAD or telephone answering device. If you have a dedicated phone line it should be in Auto or automatic receive. There is a button on the panel to change the mode to auto.
Oct 20, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Cannot receive faxes or copy, but can send out
make sure you auto recieve light is on.
check your lights the one for FAX only has to be on only.
not TEL or FAX_TAD
good luck>
Mar 21, 2009 | Brother IntelliFAX 4100 Laser Fax
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
2 phone lines causing problems for fax machine
1 line is fine as long as the fax is set to auto recieve mode
Nov 12, 2008 | Office Equipment & Supplies
Fax machines are designed to have their own dedicated phone line.
Nov 09, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
Unable to get my Intellifax 775 to receive any fax's
Things to check: Do you have a live phone line? Are you using a dedicated fax line? You can check your fax line by using the feature hook call. Not all machine have them. Or use the hand set. If you have a live phone line now check this. Is you fax set to auto answer? If it is not you need to either find how to set it on the diplay or refer to your owners manual. If this does not work after you have done this then you possibly have a bad modem.
Mar 17, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFax-2820 Laser Fax Logo
212 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
