Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a liftmaster garage door opener that is erratic
Sometimes it works fine, sometimes it doesn't work and the light flashes fast for several seconds. Same problem whether I use the remote or the wall switch. I can leave it for several hours and it works again
I have the same problem and I thought it was the temp but it has gotten worse. Unplugging or waiting a few minutes I can usually get it to open or close at least partially. I have made several small adjustment and paid for a service which all seem to help but not fix the problem. Anyone else have the same problem with 1/2 hp lift master?
Posted on May 24, 2011
Must be awfully cold . It is too cold in the early hours and don't work, it warms up in the afternoon hours abd it works. Solution move to florida
Posted on Dec 08, 2008
Garage door does operate at all. The lights don't come on and the motor doesn't operate. The "learn" button/diagnostic LED flashes are inconsistent. The number of flashes varies and...
If these problems started immediately after a lightning storm, the printed circuit board is probably damaged. Contact a garage door service company (check the phonebook) for diagnostic support.
Dec 01, 2017 | liftmaster Garage Door 1/2 Hp
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
My remote was working sometimes but now it has stopped I replaced batteries and light flashe but doesn't work to open door
If you have only one remote it is impossible to tell if it is bad or if the receiver which is part of the logic board has failed.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage door does not stay down.Comes back up with lights flashing fast.The sensors are clear and the pressure has been set.
If when the door reverses the main lights flashes 10 times it is a door sensor problem. Nothing else will cause this. Make sure the light on each sensor is lit and not flickering ever so slightly. The flickering can sometimes be difficult to see.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Door won't open
Unfortunately storms do bad things so door openers sometimes. It has most likely gotten to your logic board. You can remove that board and look for burnt or missing traces of the print. Random flashing of that LED is normal.
May 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door works sometimes and sometimes it won't
Spray some silicone in the tracks...this should help...it sounds like an alignment problem
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Craftsman garage door opener
Replace the logic board. I have seen this problem in the field. More often than not it's due to power surge or lightning strike.
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
284 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
