Question about PNY 2GB microSD Memory Card
I bought a 2gb micro sd card ,i can"t put any files
Every time it tried, it saids copyright protected.
  • honda_murphy Dec 21, 2008
    when i try to move files from music to my_music which is the file the phone recognizes for music, the files are protected and i cant transfer them or even delete them
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • PNY Master
  • 102,366 Answers
SD cards and microSD adaptors have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
No sound in video playback on laptop with sandisk micro sd card 2GB inserted
try downloading VLC player as this will play just about any file type that windows media player will not owing to copyright restrictions
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
All you have to do is
Step One (save data)
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Method 2
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
I hope this information helps. Thank you for using FixYa!
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
I have a PNY Micro Sd card and I slid the lock (write protection)
not much you can do.. try to slide the lock back, if that doesn't wrok, go shopping.. they are pretty cheap righ now..
Good luck
Oct 23, 2009 | PNY 2GB microSD Memory Card
Pny micro sd won't copy files
has the write protect been moved
Jun 26, 2009 | PNY 2GB microSD Memory Card
Cant instal micro sd card to samsung E250
Hey! samsung SGH-E250 doesn't support 4GB memory card. Try a 2GB or 1GB memory card.
Jan 04, 2009 | O2 Samsung SGH-E250 Cellular Phone
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Micro SD card
sharp, you have to format the SD through your phone and then copy the music to the folder provided by the phone for the music. make sure you check the playing / bitrate / file type of audio file that the phone is limited to play.
if you have other questions just lemme know
Sep 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Samsung micro sd memory card
THE CARD IS WRITE PROTECTED
OR THE FILES COPIED ARE WRITE PROTECTED.
SO REMOVE THE WRITE PROTECTION ITS LIKE A SMALL SWITCH WHICH SLIDES ON THE CARD .. ONLY CERTAIN CARDS HAVE IT .
NOW IF THIS DOESNT WORK
PUT THE CARD IN A PHONE AND SEE PROPERTIES OF THE DATA THERE , REMOVE WRITE PROTECTION .
Jun 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PNY 2GB microSD Memory Card Logo
204 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
