Right side turn/brake light wire is green. Running light wire is always brown on all four cornets. Left/drivers side turn/brake is always yellow. This is pretty much a universal standard.
A ROUND YELLOW CIRCLE LIGHT WITH LINES ON EACH SIDE MEANS BRAKE PROBLEMS FRONT BRAKES OR REAR BRAKES HAS A FAULT. NOW IF CIRCLE HAS LINES INSIDE YOUR POWER STEERING FLUID LOW NEED CHECKING.THE WARNING LIGHT WILL TURN OFF WHEN PROBLEM FIX.
that light is your warning light for the brake pads. One of the brake pad sensors is starting to touch the rotor causing the light to come on or flash. Have the brakes checked. You will probably be needing to replace the brakes and the sensors.
Hi, I have just translated the German text you supplied. I says the brake fluid is too low. I recommend you check fluid reservoir level (In engine compartment) If level is already at correct level, it may be due to a faulty level sensor at reservoir. Hope this helps, MMP
