Question about HP Pavilion dv9000z Notebook
Scan disk card
Yes i have a card reader. i accidentally right click and ejected my MINI/SD/MMC/RS/Plus/Mobile and now when i put my SD into the computer it wont show up under my computer.
  • kaur1523 Dec 13, 2008
    if u go to my computer and have a kodak scandisk card and after u view it, if u right click on the icon and instead of clicking the "remove safely" u will also see eject. i accidentally clicked eject and now when i put in the scan disk, the kodak icon does not come up under my computer
  • Rory Anderson
    Rory Anderson May 11, 2010
    This is odd. I have a card reader as well, and I intentionally tried to eject it, but I cannot find the "Eject" button. Where were you able to eject it? If I know that, I may be able to help.
    Novelist:
  • 166 Answers
You need to format it using Right click and then it will surely work.
Posted on Jul 21, 2009
How to unlock nokia 1001
What is the unlock code for the Nokia 1001 2b from T Mobile
Jan 25, 2013 | SanDisk MobileMate SD Plus - Card reader...
Please insert a disk into removable dish (H:) when i try to install my 2gb cell microSD memory card but if i install a sd from the cam it pulls up autoplay when i insert it but not for the cell mem. the...
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
Jul 08, 2012 | SanDisk 2GB microSD Memory Card
Can i download pictures from my aspire 6920g to a sd memory card
1. open Windows Explorer
2. push the sd card into the sd card reader with its contact side down until it is flush
3. sd card is detected and displayed as a drive called SD/MMC (N:) where N is its drive letter
4. clicking on the SD/MMC drive will list any folders that are in it
5. with SD/MMC high-lighted, click on File and on the drop-down list, hover cursor over New
6. on the New list that opens, click on Folder to create a new folder on the SD/MMC drive
7. right click on the new folder and from the drop-down list click on Rename
8. rename the folder appropriate to the photos you want to download to the SD/MMC drive
9. navigate to the photos and high-light using shift+click for a block or ctrl+click for individual
10. with cursor over high-lighting, hold down right click and drag to new folder and release
11. select from the pop-up list that appears on release to either Copy Here or Move Here
12. repeat from 9 for more photo downloading and when done do an eject before removing ....
13. for Windows XP, click on the Safely Remove Hardware icon at the right side of the Taskbar
14. for Windows 7, can do same as XP or just right click SD/MMC and select eject from the list
15. **WARNING** failing to do an eject or Safely Remove Hardware can result in corruption!!!
16. once message appears that media can be safely removed, push the card in until it clicks
17. once click is heard, stop pushing and it will pop out sufficiently to be grabbed & pulled out
Apr 30, 2011 | Acer Aspire 6920 Notebook PC
When i put my MMC dual voltage mobile card in my card reader supported slot connected to USB port it did not recognize my MMC dual voltage mobile card in my card reader. but before i put it in card reader...
I'm assuming you have restarted the computer with no luck. Go to the web site of your computer manufacturer and see if there is any update for the chipset driver or any FIRMWARE and update them. It may require you to reboot the computer. Do it. then go to START > CONTROL PANEL > DEVICE MANAGER > uninstall all UNIVERSAL SERIAL BUS and HUMAN INTERFACE DEVICE that you see there, then reboot the computer. After that your computer will detect new devices, let it finish. run a scan of your computer for possible infections then reboot the computer. You should be fine then.
Apr 22, 2011 | Computers & Internet
MY NIKON 700 WONT LET ME UPLOAD MY PICTURES ON THE COMPUTER I CONNECT IT TO THE USB CORD & NOTHING HAPPENDS WHAT DO I DO???
take out thememory card and put it in the "SD/Mini MMC/RS/Plus/mobile" slot and autoplay window should pop up then you're set
Jun 13, 2009 | Nikon COOLPIX L18 Digital Camera
Write protection in N70 nokia mobile MMC card
there are many things you can do to remove write protection but you have to give rating to me. Here is the first one 1.)go to MY COMPUTER 2.)right click on MMC drive 3.)click on eject. 4.)remove MMC form card reader 5.)again put it back (if at once it didn't worked try again step{2,3,4}
second method is: sometimes your USB port locks it try some other USB port & then put the MMC in memory card. pls rate me thank you
Feb 14, 2009 | Nokia N72 Cellular Phone
Disk error minisd N73
just find a card reader for sd card , u should have mini sd to sd converter in ur mobile box take it or buy it from street shop , and then put it in card reader in laptop then go to my computer and right click on the card icon in disk section and then select format from the list here u go, but u should first check ur card might be faulty try changing it first
Feb 02, 2009 | HTC Touch P3450 Smartphone
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
From cell to Pc
Hi Big Bran,
There are 4 methods to transfer pics n videos from mobile to pc. They are through :
1) Bluetooth
2) Infrared Device
3) PC suite via USB data cable
4) MMC reader. ( memory card reader)
I think u r new user of this mobile phone. For u, I recommend u to use Memory card reader. It is very easy and fast.
Process : Take out memory card of ur mobile and insert in the MMC reader. ( It is easily found in the market and they provide u with adapter like a micro SD memory card to insert ur mini Memory card in it ). Join the MMC reader fitted with ur MMC in PC. Now, it shows a new drive like as CD drives. Now copy or transfer pics or mp3s or videos via it like u do in other drives(pen drives, floppy drives).
I think u may have mini Memory card. For it to be fit in MMC reader, u need a small casing adapter which is like a micro SD memory card. INsert ur MMC in it, and ur drive will be shown.
Looking for ur kind feedback,
SAJAN (sajwhat_2003@yahoo.com)
May 05, 2008 | Motorola Mobility RAZR V3
HP Pavilion dv9000z Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
