Question about RCA P52928 52" Rear Projection Television
Adjusting convergence I have a 1999 52" P52928 Projection TV. The set was transported on its back and now the convergence is out of adjustment. Is there a way to adjust the convergence in the set up menu? I have been through all of the setting options, and can not find the convergence setting. I have an older Projection RCA that can be adjusted under the menu options. Any help will be appreciated.
  • 2 more comments
  • Anonymous Dec 02, 2007
    All three colors are out of alignment. The screen section under menu does not give me Option# 6 (Adjust Projection TV). It only gives me 1-5 under the screen section.
  • Anonymous Oct 13, 2008
    I have same problem My tv HAD a choice #6 to adjust But it is now gone I have done this before Dont
    know how it is missing
    Have same Problem I have adjusted this before BUT option #6 is gone now. Whats up it was there before
  • mit00032 Feb 15, 2009
    tv screen looks like a bubble and the colors are off
Try unplugging and waiting over night and then repluging it in this will reset the computer
Posted on Mar 31, 2007
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
Words have a shadow effect about 1/2 inch above the real image.most easily seen on words ( sentances)i have the rear of the tv apart, but can't figure out how to adjust the lights up and down to fiw the...
You need to use the remote control and go into picture set up, to adjust the convergence settings. See your owners manual. If you can't adjust the picture back in then the convergence amplifiers are bad and will need replaced.
Dec 05, 2010 | RCA P52928 52" Rear Projection Television
My convergence is off I believe the antenna from the Wii game through it off now my t.v. shows a 3d picture. I opened the back and adjusted the red lense but the convergence is still off it doesn't show 3d...
keep adjusting the tv until the tv shop has to charge you twice as much for having to correct all your adjustments and for repairing the convergence board why would you adjust something that is factory set? did you think the lens slipped out place?
Dec 30, 2009 | Sony KP-61V90 61" Rear Projection...
Not able to adjust convergence. Tv thinks its a tube tv not a projection tv.
Thats usually caused by the STK730-130 Convergence IC. You can get the replacement IC at www.tvrepairworld.com they will also assist you with how to replace it.
Nov 26, 2009 | RCA P52928 52" Rear Projection Television
How do I get the front panel off my Sony 46in projection tv to adjust the red line conversion.
You cannot - or should not adjust the convergence manualy. The TV has a built in flash focus button on the front panel that you can press. Some sets also have a convergence menu. Use those. Adjusting the knobs in the TV will only make things worse.
Nov 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Magnavox 51" 51MP392H seems not to have any reds in picture.
his is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
Also - Dull video problems...
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 12, 2009 | Philips 46PP9302 46" Rear Projection...
Projectors need to be adjusted i guess they moved when TV was transported
do not move crts manually. go into the menu and adjust the picture's convergence.
Jun 18, 2009 | RCA P61960 61" Rear Projection Television
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence
Replace (2) STK392-150s these are your convergence ics.
Nov 12, 2007 | RCA P52928 52" Rear Projection Television
RCA P52928 52" Rear Projection Television Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
