Cars & Trucks Logo
Posted on Jul 04, 2012
2000 ford explorer air cinditioning blowing low cool air added freon clutch working properly condenser is not iceing, but sweating still no changein cooling. not cold air, but low cool air, why is this happening?
A
Anonymous
If you attempted to add to the system, you most likely
added some air into it also
Unless you have a vacuum pump & can leak test,
evacuate the system & recharge yourself,you will
have to pay someone to fix things
5 Related Answers
Anonymous
  • Posted on Jan 07, 2009
SOURCE: 2000 FORD ESCORT AIR CONDITIONER BLOWS BUT COOLS ON AND OFF
Hi Elena,
Get the wiring checked for the compressor also some of the ford escort sedan model had the push button for the compressor and rotation for the blower. Sensor is only for the speed variation of the blower if i am right you should have the three speed blower switch on the dash board. if it's just blowing and not cooling just push the same button and check it should start cooling.
thanks
Have a nice day!
Anonymous
  • Posted on Apr 28, 2009
SOURCE: A/C not blowing cold air, warm air on the driver's side
have you checked the mixing motor and the door?pull out the glove box you will see a white motor remove it 5/16 or 8mm plug it back in run the system to see if the shaft on the motor works then check where the shaft fits in the top of the door if it's broke cut the box under the door w/ a dremal remove door fix if posible reverse steps good luck.i'm doing this now i fixed the oor but the compressor wont come on any ideas???????????
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 07, 2009
SOURCE: I HAVE A 1996 FORD EXPLORER,MY AIR CONDITIONER
try replacing the compressor cycling switch in the low side at the accumulator
litoshop
Josue Almodovar
  • 298 Answers
  • Posted on Jul 12, 2009
SOURCE: air conditioning will not cool. Can smell freon
you need to see a A/C tech. you my have a leak throw a seal or evaporater needs replacing
Anonymous
  • 18 Answers
  • Posted on May 27, 2010
SOURCE: My 2003 Ford Explorer air conditioning is not
Your system is low on refrigerant and needs some more R134. Go to your local parts store and get a recharge kit which will come with a can of R134 and a hose to connect the can to the system. The fitting on the system will be on the passenger side of the vehicle, under the hood. Follow the instructions in the kit and you should be ok. Don't add more than you need to get the a/c blowing consistent cold air. Too much refrigerant can be just as bad and ineffective as too little.
Why does my 2000 dodge ram 3500 pickup ac blow hot when I give it gas or under accelartion
check for clutch slippage --and when charging system was it done at idle [which is incorrect ] or at raised rpms may be low on freon
6helpful
8answers
Why the compressor, air conditioning clutch be clicking in and out?
if on and off consistently [short cycling ] the usual cause is low or short on freon others are low pressure sensor switch -or clutch failing but the usual problem is freon level
2answers
2009 mariner air conditioner blowing hot air. How to fix?
Assuming it doesn't need freon added it could be a bad high or low pressure switch. When the ac is on does the air conditioner pump clutch cycle on and off?
A/C blowing cold air when car is cold, but clutch disengages when car heats up
Low of freon, have it charged to proper lvls with CORRECT freon/refridgerant
1helpful
2000 pontiac grand prix ac problem
If the compressor is working, a mechanic would check the low and high gauge pressure.
The freon has to flow thru the system to work, and the cooling fan draws air thru the condenser to get rid of the heat from inside the car.
If the ac clutch is working but the gauges show equal pressure, the compressor may be faulty.
2helpful
AIR CONDITIONER
Could be a list of things including low on freon, low pressure switch, relay, or the a/c clutch on the compressor.
2answers
A/C not cooling
Feel of the large ac line going into the firewall,and see if it is cool,or cold,also,the condenser could be restricting flow threw it,on the inside,we really need gauge readings for low side,and high side to diagnose the problem.
AC blows cool not cold, checked freon seems to be
I dont know how you can check it for being full or not? but most likely its low. If you have it on, and high speed like 2000 rpm and the a/c clutch goes on/ off in a few seconds, the refrigerent is low.
1helpful
I have a 2002 Ford Mustang. My air conditioner is not working properly. It blows into the defrost when I take off and when I let off and go a steady speed it blows out cold. It blows hot air sitting at...
if it never comes out face vents then u have a door actuator motor not working ,,if it jumps around letting off throttle then it is a vacuum problem vacuum under hood going into the firewall needs to be checked,,and vacuum resovoir might have hole in it if it is vacuum cantrol,,,the reason for warm and cald temp changes is probley not enough air flow threw radiator and condenser this will rise the high side and low side heating up the freon and it cant cool the freon down enogh to get col air ,electic fan not coming on would cause this or fan clutch (if it has one ) would also cause this .look for fan relay not working ,also did u change accumilator and dryer? ,also may have blockage in condenser i hope i shed some light on the problem
1helpful
Air Conditioniong not working
U may be low in Freon gas.
When Freon is low there's low pressure switch that will prevent A/C compressor clutch from engaging to protect it from failure.
So, first check Freon pressure & any leaks form lines & hoses fittings.
Even if the fan is working, that doesn’t indicate proper compressor OP'S.
Look at the compressor front side you'll see the clutch stationary while the AFT pulley moving.
Then put air-condition compressor switch to ON (Engage),
You should see the clutch engage & start rotate,
If NOT, this is very clear indication u r low in Freon.
Regards;
MAR
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
