Question about Maytag PAV2300 Top Load Washer
Maytag washer the washer wont spin or drain water.
  • 750 Answers
Welcome to Fixya
My name is Huum,
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Cabinet Removal - Whirlpool / Kenmore / Estate / Roper Direct Drive Models
The diagrams referenced in this article are available for download in the Attachments section below:
1.) Preparation
It should be obvious but the first step should be to unplug the washing machine. Then pull it away from the wall a six to eight inches.
2.) Rotate Control Panel
Locate and remove the screws (items 49 on the Control Panel Diagram) that are installed in the base of the both the left and right side control panel end caps. Once the screws are removed, pull up and forward on the control panel. The control Panel will rotate toward the back. Tilt it back until the hinges catch. Allow it to rest there.
3.) Unplug Harness
With the Control Panel Assembly folded out of the way you should now disconnect the wire harness that connects the console to the main case. The harness plug disconnects from the top of the cabinet.
4.) Remove Clips
Use a flat head screw driver to remove spring clips (items 6 on the Cabinet Diagram) from both the left and right side of the cabinet top. This can be accomplished by inserting a flat head screw driver into the spring clip and pry toward the back of the machine. Once each clip is loose, feed the clip out of the hole in the rear panel.
5.) Detach Cabinet
Now open the lid. Use one hand to hold the lid open and the other to grab the front of the cabinet opening exposed when opening the lid. Tilt the entire cabinet assembly toward you by pulling both the front cabinet lip and the lid. This should release the rear locking tabs.
Use your knee as a lever to lift the front of the cabinet away from the washing machine base. This should release the front locking tabs and complete the removal of the cabinet from the machine.
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
Posted on Dec 15, 2008
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
Sep 12, 2013 - Uploaded by
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
The water in my stackable washer and dryer wont drain
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Waher wont spin
first, if it's under warranty, have them service it, if not then....
the maytags work mainly on belts with a forward and reverse on the motor. forward washes, reverse drains and starts spin cycle. if the motor does reverse and drains the water, then it's probably the transmission of the washer. these washers have 10 years parts on the transmission, so I would have a service repairman come out and fix it. you'd only pay for the labor and the transmission would be free.
Jun 21, 2008 | Maytag SAV2655A Top Load Washer
My maytag top washer want spin out
Check the drain pump. It could be blocked or jammed. Remove the front panel and the pump is easy to access. There will be a hose from the bottom of the outer drum to the drain pump. Remove plug from wall socket before attempting to remove any cover.
Oct 31, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag PAV2300 Top Load Washer Logo
183 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
