Actually, what you're doing already clean up the data in memory.
If the memory still contain data, maybe there's something wrong with the printer.
Run a self test print whether the printer is okay or not,
Turn on the printer while holding down the LF/FF button or Load/Eject button. If it start print, that mean the printer okay. Press 'Pause' and turn OFF the printer and then turn On back to stop the self test printing.
SOURCE: Epson LQ-1170 ESC/P2 can't running in windows 98
You need a compatible driver to link the printer. Check online for driver compatability with older OS.
SOURCE: HP 1220C. I had a paper jam, removed the back and
Make sure when you reset it you also remove the data cable from the printer, then unplug, wait a few minutes, or up to 30 minutes, then reconnect and restart.
Also see possibly helpful links here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Epson Status Monitor 3 :
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
