I searched the most common problems on your website, for some reason mine hasn't been listed yet. The error that came up on the printer screen read "Engine Fuser Low Heat Error." Obviously the printer hasn't been over used because it would say too hot, what is the problem?
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Toner is stuck on the fuser thermistorof the fuser lamp is faulty
Il faux changer une piece qui se trouve dans le bloc four
c'est le termostat
SOURCE: Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
what i can do
Engine fuser low heat error
engine fuser low hest error
