Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP6110 default paper size for copying
I have a HP6110 all-in-one.  The default paper size for copying is set to Letter but I want it set to A4.  At present every time I copy something I have to go into the menu to change the setting.  Is there some way of changing the default setting?
    Guru:
  • 1,049 Answers
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Posted on Dec 12, 2008
  • NA NA
    NA NA Dec 23, 2008
    Was this helpful?
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Paper size
check default setting with bypass try
usually it is letter size change into the a4
Apr 21, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
Paper size setting
Change the marketing area from EU to US in Service mode.
Sep 02, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
Copyer problem
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
When I print my letter, I set my defaults on my computer with Letter size. But pn the printer, I can't figure out how to change the cassette from A4 to letter. It's driving me crazy. Please help me default...
Go through the following
Start=Settings=printers and faxes=right click on the isatalled printer=printing preferences=change paper size from A4 to Letter. This will now remain as default.
Regards,
Manoj Joseph
+91 9352008418
Jun 18, 2008 | Canon Office Equipment & Supplies
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
HP OfficeJet 6110 All-In-One InkJet Printer Logo
196 people viewed this question
Seeker5211
Seeker5211
