Question about Panasonic KX-FP81 Plain Paper Fax
Panasonic kx-f100 fax prints and sends a page on 2 pages- too big
This old fax machine prints and sends 1 page faxes so large that they come out on two pages. How can this be adjusted or configured on the settings? Thank you!
    Sergeant:
  • 284 Answers
It sounds like one of your rollers is not making contact with the paper. either the roller is dirty or you need a new one
Posted on Dec 09, 2008
Is there laser fax model 612? Its the same as 611 or not?
Yes those Panasonic models are the same just the KX-FL 612 is different from KX-FL 611 in some specifications like as example:
611 prints maximum 14 pages per minute and 612 prints 16 pages per minute. The document feeder on 611 can feed maximum 20 pages while 612 can feed 30 pages and some other compare stuff like those.
Mainly KX-FL 612 is improved version of KX-FL 611
Jul 11, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
Wrong in receive fax (only one page coming)
Contact the sender and tell them to press STOP when their machine starts to dial.
Jun 28, 2009 | Panasonic KX-FM131 Fax
Fax Spam
I couldn't find anything specific to delete the memory without actually printing it,
here's a copy of the manual if you need it:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FHD331%20Plain%20Paper%20Fax.pdf
May 26, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Erase fax in memory
Unplug the fax machine for 1 hour.
Jan 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Panasonic kx-f1100 fax prints and sends 1 page on 2 pgs- 2big!
I found the solution to my problem: Press Menu, Pound Key (#), 35 to set copy size, 36 to set fax size, press Start/Set, then use up/down arrows on right side of the machine to select 92%, 86%, 72%, or Off. Press Start/Set to select desired setting.
Press Menu to exit!
Dec 08, 2008 | Panasonic KX-FP81 Plain Paper Fax
Panasonic kx-fpg376
more then likely the sending fax had a problem and did not send you the complete fax. You should have them resend the page you're missing.
Hope that helps...
Jun 19, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Dec 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic KX-FP81 Plain Paper Fax Logo
105 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
