My computer is in safe mode, dont know what to do to make it run normal again?
  • 20 Answers
Reboot the computer. Keep pressing F8 while it is rebooting to be presented with the advanced boot options menu. from here you can use the arrow keys to select start windows normally.
if you can't get the advanced boot options to come up by pressing F8, hold the power button while windows is booting to turn off the computer. Windows will sense that the PC did not boot properly and will display the advanced boot options menu. From here you can select to start windows normally.
Posted on Dec 08, 2008
Vista only runs in safe mode
1. Press the Start button.
2.
Type msconfig in Start menu or click 'run' and type msconfig.
3.
Open the program. (Click msconfig icon if it doesn't open automatically)
4.
Also, open the command box. Click Start > run > and type cmd.exe and open. (If the above method does not work, using "msconfig", your "System Configuration Utility" program should open on your screen.
5. Click on the "General" tab on the utility program. Select the "Normal Startup" option. Click "Apply" and "Ok" to confirm the change back to normal mode.
6.
Follow the on-screen prompts to restart the computer. Your computer should reboot normally.
7. IF
this doesn't work: Click on the "Boot" tab in " msconfig" > the "Safe boot" option should be unchecked.
IF that doesn't work, go to "msconfig" again and click the Startup tab. Disable all startup programs or, if you know which one is causing the problem, just a single program.
Hope this helps! Godspeed
Feb 06, 2014 | E-Machines Computers & Internet
Tip
How to Turn Off Safe Mode on Windows Vista
The Safe Mode is used to detect the technical and software problems in windows Vista. This is an effecting way to diagnosing the problem, that's why most of the technicians prefer this way to resolve the problem. But Safe Mode disables the most of the advance functionality of your computer. So use the Safe Mode only for diagnosing the problem and as you diagnose and repair the problem get back your windows to normal mode. <br /><br />For reverting back to normal mode at windows Vista, an option occurred which has to be select within limited time and if you select the Normal Mode option within this limited time, your windows will revert back successfully but if you waste the time, you have to restart your computer again for getting this option. You can select the Normal Mode option through arrow keys or by pressing the number at which the Normal Mode will appear.<br /><br />Sometime your computer does not display the Mode Selection Menu. This is not a problem you can get this menu and revert back your windows Vista into Normal Mode through the following instructions.<br /><br />Instructions<br />If you want to revert your Windows Vista into Normal Mode from the Safe mode but your system is not giving you option to select the mode, follow the given instructions: <br /><br />Restart Your Computer: To restart the computer you need to take the following step:<br />- Click on "Start" button at the left side of Task Bar. In Safe Mode of windows Vista the Start button appears at the same place where it appears in the Normal mode. Select "Turn Off Computer" from the Start Menu. Then, Select 'Restart" from the pop-up menu.<br />When your computer has been shut down place your finger at F8 key. As your computer starts to boot computer devices for restarting your computer, press F8 key again and again unless a menu appears on the screen. This menu is Mode Selection Menu.<br /><br />Note: If your computer won't give you Mode Selection Menu at the screen that's means you have lost the time of getting option. In this condition restart your computer again and again, and then press F8. <br /><br />When you get Mode Selection Menu on your computer screen, stop pressing F8 key. Now choose the Normal Mode from the list by the following method:<br />- You can select the Normal Mode by pressing the number on which Normal Mode appears in the list.<br />- You can select the Normal Mode manually through the Arrow Keys. Press the down key to reach at the Normal Mode option in the list and press Enter. <br /><br />Then wait for a while to reboot your Windows Vista in Normal Mode. <br />This is the method of changing Mode in windows Vista. You can follow these instructions at any time to revert your windows Mode.
on Jun 24, 2011 | Computers & Internet
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
My computer is in safe mode and want to exit out of safe mode how do i do it?
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Nov 15, 2010 | E-Machines eMachines Desktop PC
How do I get my computer out of safe mode?
Just restart your PC and when it boots up again select "Start Normally".. that's all
Nov 09, 2010 | Computers & Internet
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
My computer is rebooting over an over ....dont have time to do anything....now i open my computer on safe ....mode what should i do??? i have window xp
If your computer fully loads Windows, than starts a restard process you are looking at having an annoying virus. Since there are several different viruses that can cause this problem, if this is the reason for the restarting, you would be best off loading Windows in safe mode (using the F8 key before Windows starts to load will give you a menu with options like SAFE MODE) and than trying to scan it for viruses.
If your computer doesn't actually load Windows, but restarts after the Windows loading screen, you could have a corrupt driver causing Windows to restart. If your computer were slow, you would see the error message, faster computers go through the error screen too fast. The best way to determine this would be to start in SAFE MODE and see if the same problem exists.
Let me know what happens after you start in SAFE MODE. 6 Pts Rate Answer
Jul 09, 2008 | Computers & Internet
When i turn on the computer it doest work i dont get to go to the main screen its show windows loading files
This can be the product of a system files corruption, or possibly a virus that is causing your pc to reinstall itself (in a way at least) Although I haven't seen something like this in quite a while. When you boot up the PC try to get into safe mode by pressing F8 until you get the boot menu, if you can get into safe mode you should be ale to diagnose your problem or use something like system restore to attempt reverting the situation. You can also insert the original Windows CD and do a repair install, although you will need to reload your updates, this can have many benefits performance wise.
Jul 08, 2008 | Computers & Internet
Computers & Internet Logo
97 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
