Question about Garden
Cant find the screw to tighten chain on saw
I cant seem to keep my chain tight. I cant find the tightening screw. All I can do is loosen the 2 bolts and pull the chain tight. I have no owners manual. Can you help me please.........doug wilhite
  • 1 more comment
  • mindyrussell Jan 02, 2009
    I have the same problem. Let me know if you get an answer. Cleaning it doesn't help.
  • latazza108 Jan 18, 2009
    i have a Poulan in which i paid $170 for. i thought i was buying a quality product that was easy to tighten the chain.
    WRONG!
    i know where the tighten wheel is, but it doesn't help. cleaning doesn't help either.
    i won't EVER buy a Poulan product again!
    the chain get very loose very quickly. it's very hard to keep tightened.
  • Anonymous May 25, 2009
    Same problem here - first, tightening the saw is major surgery; then it does not stay tightened. I will NOT buy another Poulan.
  • 211 Answers
Hi
You have to look from profile to the chain saw(clean it)
best regards savumihai71
Posted on Dec 10, 2008
How do you tighten the chain
Well it kinda depends on the saw you have. But either way you have to losen the bolts on the side of the saw by the bar and look for a flat head screw either between them bolts or at the front of the saw, some were beside the bar and chain. turn till chain is tight but not to tight and then tighten side bolts. Now if you have an older saw the do the same thing with the bolts only on the bar there should be a slot for a flat head screw driver just turn till chain is tight and tighten the bolts back up...
Apr 19, 2015 | Garden
Chain keeps going tight on my johnson red saw why
I think you should make sure that when you tighten the 2 nuts that hold the bar, that you raise up on the bar while you tighten nuts. That way the bar cant move up and tighten the chain.
Jan 26, 2012 | Televison & Video
Drive belt keeps falling off.
Dive Belt??? You mean CHAIN? Loosen the one or two bolts where the chain enters the body of the saw. They are right on the outside of the saw. Then, in front of the bolts, near the BAR, there will be a Bar-Tensioner screw. It is usually a flat-head. Turn this screw to extend the bar, thereby tightening the chain. Then, retighten the bolts. Leave the chain a little bit loose, because as you use the saw, it will heat up, and the chain will get too tight, resulting in premature bar wear.
Jun 11, 2011 | Garden
The chain on the 16 in chain saw keep slipping. Seems the thumb screw will not stay tight? Who can check this and fix?
First thing I would do would be to loosen the thumb screw fully so the chain is as loose as you can get it Next, loosen the chain bar and pull it out as far as possible which will take up the slack in the chain itself. Re tighten the chain bar. Afterward, you can perform detailed adjustment on the chain by playing with the thumb screw.
This solution has always worked for me and my various chainsaws.
Apr 12, 2011 | Remington 16" Electric Chain Saw
Model 338 chain saw, chain too tight needs to be loosened off
There is a hole in the brake/clutch cover (that you take off when you change your chain) under the attachment bolts through which a bolt protrudes. Use a small screw driver or the wrench that comes with the saw to turn this bolt (it has a slot in it) to either tighten or loosen the chain.
Hope that helps.
Handie Andie
Mar 21, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Chain came off and it is too long and can't get it back together.
I take it to mean the exact same chain that was on there before now appears to be too long. Obviously, this is a clue. These things don't stretch.
All chain saws will have the chain get loose with use. You should be checking this and make an adjustment before it gets so loose that it comes off which is very dangerous and can cause injury.
When it appears too long, I can think of two things that may be happening.
1. It really is too long and you need to find the adjustment screw near the base of the blade and screw it in (with a long screw driver or the tool that came with the unit when you bought it) which pushes the chain saw blade further out and tightens the chain. Usually, to get the blade back on, I have to tighten the screw and loosen the chain and then make it tight again after everything is together, so experiment with the process of tightening and loosening the screw. (Note, the loosening and tightening assumes that the nuts on the big bolts that hold on the blade have been loosened to allow the blade to slide. Make sure this loosening was done first.) 2. The chain may have slipped of the sprocket gear that drives the chain. If you have not taken the blade off you can't see this gear well and might not notice. Disassemble the blade and put it back together seeing that the chain is properly seated. Don't screw the bolts tight before you adjust the tension in the blade as in my remarks above. Tighten the bolts well, as the final step.
Nov 12, 2010 | Remington Electric Pole Saw
Chainsaw chain will not tighten on the guide bar
The two nuts on the bolts for the chain bar, need to be loosened.
Then the tension screw is tightened by turning it Clockwise. (To the Right)
If the chain doesn't tighten,
1.Insure that the nuts are loose enough, so that the chain bar may slide.
2.Insure that the tension adjusting screw does not have stripped threads, nor the threaded part of the case it screws through.
Oct 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
The chain popped off and I can't get it to fit back on.
Losen the bar mounting nut, then losen the chain tension adjustment screw until the chain can be reinstalled, then tighten the tension screw until the chain just sags 1/8" or so at the center of the bar then retighten the bar mounting nut.
Sep 10, 2009 | Remington 16" Electric Chain Saw
The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Jun 08, 2009 | Homelite ZR10926 16 Chain Saw
Unable to tighten chain .. too droopy.
There are usually two 7/16" nuts on the side of the chain saw. Loosen those a little first, then turn the screw to tighten the chain - not too tight or you'll stretch out the chain when you use it. Don't forget to re-tighten the two nuts before using the chainsaw.
May 16, 2009 | Remington Electric Chain Saw
Garden Logo
307 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
