Question about RCA HD52W58 52" TV
60 inch tv older model
We have one an wonder if the base comes off to get it in our basement
  • 121 Answers
Sorry
Posted on Dec 08, 2008
I how a 60 inch tv that need screws for the base but don't know what size screws
CALL LG CUSTOMER SERVICE AND THEN GO TO HOME DEPOT ETC.
THEY ARE GOING TO BE STANDARD BOLTS.
Apr 16, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
Sep 04, 2009 | RCA 32V550T 32" TV
Older Ge Hotpoint Dryer will tumble but not light the gas to heat
You state it is an older dryer, so I'd suggest replacement. The water may have damaged numerous components, including the motor, which would be costly to replace.
Aug 28, 2009 | Hotpoint NWSR483GBWW Gas Dryer
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Philips 60
First of all,this is a major labor intensive repair on Philips TV's changing the blue CRT because the new CRT does not come with the coolant that is sealed between the lens and the tube.If you have never done this type of repair before you should not attempt. Changing the convergence board is one thing (you can solder in two STK392-120 IC's and repair the board instead)
but changing the CRT's can be a nightmare.If you are brave go to PARTSTORE.com and get the parts $600+ (I would order the service manual too...you will need it)
Aug 27, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60 inch tv
There is nothing you can do to repair the convergence problem it sounds like you have. If it is the older PTV set with crts it will probably cost $200.-$300. for the average repair of this nature.
If it's a DLP model, no convergence in those. Most likely a Light Engine. $500.-$800
Mar 12, 2008 | Televison & Video
Need a screen cover for 60 inch philip
Hello lcastillo225,
I think that you just called my shop, well in any event what you need to do is to contact the manufacture and order the part from them. The part is called a fresnel screen. Give them the make and model of your set and they will send you the part once you order it, however I would suggest that you get a qualified TV Technician to install the fresnel once you receive it. The cost will be around $150- $350 (average based on industry installation prices) for labor.
I hope this helps,
Thank you,
Shuttle83
Jan 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Redirect please: COLORTRAK 2000 - WORKS OK, Very old
John,
They say " beauty is in the eye of the beholder " ! At times,
I have older customers that want wooden floor models,but it
is a rare request.......older sets generally are not compatible
with modern equipment, therefore they have very little actual value or merit............if you could get a few dollars and the
recipient of the old-timer is satisfied...that's the ticket !!
Dec 20, 2007 | RCA 13R400TD 13" TV
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
RCA HD52W58 52" TV Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
