Lexmark 4550. Disk wont install on computer,keeps saying wrong format.
  • 1 more comment
  • paleman07 Dec 22, 2008
    I have a lexmark printer 4550 and I can not install it. I have a dell computer.
  • JDTec
    JDTec May 11, 2010
    And what OS, XP, Vista or Mas OS?
  • JDTec
    JDTec May 11, 2010
    What computer do you have?
    Master:
  • 461 Answers
Download the drivers from the Lexmark Website and try it
Posted on Dec 08, 2008
SATA on dell dimension 4550 with Debian
look in the devicemanager what does it say.
update thrue the deviemanager or search the internet
May 26, 2013 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 BOOTMGR is missing error message
To repair missing orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
Jul 09, 2012 | Dell Dimension 4550 PC Desktop
My Lexmark 4550 will not sacn wirelessly, how do I
Hello. Try to run the installation cd in your computer again. If you haven't tried to uninstall the software from your computer, the cd should give you three options: Install a Printer, Repair/Update and Install Additional Softwares. Choose Repair/Update and just let it run and finish the installation. Also, make sure to allow all Lexmark and printer communications in your firewall. Try to scan wirelessly again. If problem needs further troubleshooting, I advise you to call Lexmark.
Mar 31, 2010 | Lexmark X4550 InkJet Printer
When I install a memory sd disk, the camera says it needs to format. I format it and it then says it has to format. It just keeps saying that it has to format and wont alow me to take any pictures at all,...
Try to format the memory card on your computer first. After that, test the camera and see if it can detect the memory card.
To format the memory card on your computer, you need to have a card reader or a memory card slot on your PC. Once your mmc gets detected, go to My Computer and then right click on the Memory card and then click Reformat. Choose default settings and then check Quick Format.
Let me know how it goes.
Dec 24, 2009 | Kodak EasyShare C913 Digital Camera
I have got a 2gb scan disk memory card i cant access it or format
Hello Friend,
Here is a method to try:
  1. Backup all data from your hard drive to another hard drive or CDs or DVDs.
  2. Turn off your computer.
  3. Insert the USB drive to a USB port.
  4. Turn on your computer.
  5. Hit the F8 key when prompted to get to your system bios. Some computers required the Delete key or F2 instead of F8. There should be a note on the screen that specifies the key.
  6. Navigate your bios (usually using your cursor keys) to boot from CD drive first. Save and exit.
  7. Insert your operating system disc aka Operating System Restore disc. Your computer should restart. If not, restart it yourself.
  8. Follow the instructions for installing your operating system. When the option to select which drives to format comes, you should be able to see your USB disk in the list.
  9. Format the disk with FAT32 for Win98 or previous. Format with NTFS for anything after e.g. NT, 2000, XP etc.
  10. Depending on your options, you may be able to opt out of the operating system install at this point. If it was running well beforehand and you can, leave your other drives alone and quit the re-installation.
  11. Reset the computer to boot from the disc drive the operating system is on instead of the CD drive as before. You should have your working flash drive detecting and usable now in windows.
  12. If you didn't get the option to opt out of the re-installation, continue to follow the instructions onscreen and complete the re-installation, formatting whatever drives are required. Note: Do not try to install your operating system onto your USB disk drive. Also be cautious when formatting to keep in mind all data could be lost.
Best Regards,
Oct 29, 2009 | Electronics - Others
Computer wont communicate with printer
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
Disconnect your USB cable from your printer.
Uninstall all Lexmark printer drivers on your PC.
Download the correct Vista driver for your model.
Install the driver on your PC.
Important Notice -
Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
go to Lexmark website using this link: http://support.lexmark.com/perl/support/support.cgi enter your product number (X4270) and you will find your driver for Vista. Good luck.
Mar 30, 2009 | Lexmark X4270 All-in-One Multifunction...
The keychain wont format- it wont open the program!
It seems you have not installed the `keychain' software If you do not you might receive a message that says `the drive is not formatted'.
Dec 30, 2008 | Symantec WinFax Pro for PC
All in one printer x1240
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Nov 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x3430 printer
X3430 lexmark wont let me scan any of my pictures.
it says it's to busy.
Nov 27, 2007 | Computers & Internet
Lexmark 1200 series all in one
I purchased a lexmark 1200 series all in one printer and cannot locate the cd that came with it. Is there a way to install it without the cd? I tried but it says can't find hardware.
Sep 03, 2007 | Computers & Internet
133 people viewed this question
jasbo
jasbo
