Question about Fossil University of Oklahoma LI2282 Sport Watch
2 Fossil Watches wont work
Replaced battery on Fossil Blue mens and womens. Both quit working. Assumed both needed batteries. Replaced both batteries and still dont work?
  • 103 Answers
Fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
Posted on Aug 04, 2010
  • Jane Fielding Jan 28, 2012
    most batteries will quit sometimes very soon depends on shelf life before you purchased it. i have had customers in the past (rare but happens) that would walk out of out store and come right back in cause the battery had quit we replace it and it was fine. i have about 10 fossil watches personally myself some quite old just change the battery and find somebody that will give you a warranty on it as well
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here: http://www.mastersintime.com/en/straps/
Oct 17, 2017 | Fossil Watches
I have a ladies Fossil watch #AM4168. The battery went bad on it and when I changed it out with a brand new battery and the second hand won't move. I took the battery out thinking I was sold a bad battery...
It is a common logic problem. The watch stopped working. You assumed it was the battery; hence your assumption was wrong. Therefore the obvious answer is that the watch broke and that a battery would not help unbreak it.
Oct 21, 2013 | Fossil Sport Collection watch #AM4168...
My fossil big tick has stopped working
Lots of possibilities. One is they put in a dead battery, don't laugh. I have seen this several times. Two, the watch has a problem other than the battery and you assumed the problem was the battery when actually it is something else. I have more but these two are the obvious. Find a watchmaker.
Oct 06, 2012 | Fossil BQ9177 Wrist Watch
What type of battery does the Fossil Ch2473 use? I called Fossil and they could not help me, instead they insisted I pay them $15 to replace the battery and wait 2-4 weeks for shipping. However, I...
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike. However, the Fossil CH2473 includes chronograph functions, which means that you can have multiple motors inside the watch running simultaneously. As a result, it's possible that this watch will require a different / bigger bigger. However, if it's not one of these batteries, or even if it takes a 3-volt lithium battery instead of a 1.5 volt watch battery, it will still be something pretty mundane.
In general, common batteries like the type I expect you'll find inside your watch are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur. Lithium batteries, whether "brand name" or generic, should have the same performance curve.
If you do open up your watch to change the battery and don't recognize the battery type/code on your battery, don't give up. Watch batteries have different numbering schemes, depending on the manufacturer. Here's a link to a cross-reference chart that will help you "translate" one code into another. I would suggest starting by looking at the #377 line to see if one of those cross-reference codes matches what you have. However, you may need to look around the chart to get an exact match:
http://www.watchbatteries.com/custom.aspx,,id,,75
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 15, 2011 | Fossil CH2473 Watch for Men
I am needing to find out what kind or size battery The Fossil Blue AM-3574 takes and where I can purchase them.
These batteries are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur.
May 12, 2011 | Fossil Blue watch #AM3574 Watch for Men
I have a Fossil AM-3719 watch. I bought it in October and it just stopped working. Shouldn't the battery last longer than that? Where can I get another battery? I'm located in London, Ontario, Canada.
Before you take any action which may invalidate your warranty, have a word with Fossil costumer service (go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html).
All the watches that I have owned ran for more than a year and Fossil may sort it out for you.
Apr 11, 2011 | Fossil Casual Metal Dial AM3719 Watch for...
It does'nt work
I would try a new battery first if you havent done so yet.
If new battery does not work, you can send your Fossil watch to:
http://www.fossil.com/attachments/en_US/watch_repair_form.pdf
Aug 23, 2010 | Fossil Skeleton BG2063 Watch for Men
Broken digital clock
First of all visit the FOSSIL site from my tips and tricks. If you can not find the solution there, check out if you have two batteries in your watch. It is quite common to have two batteries in Fossil watches (same do Timex). If nothing helps, you have to visit your nearest watch repair shop.
Jan 21, 2010 | Fossil Leather Casual Ana Digi Black Ip...
Fossil University of Oklahoma LI2282 Sport Watch Logo
1,124 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
