Question about Vivitar 900x 28-piece Microscope Set
CAN'T GET IT TO WORK
VIVITAR 900X MICROSCOPE FIRST TIME USING CAN'T GET THE LIGHT TO COME ON TO SEE THE SLIDE??
  • djr300 Dec 26, 2008
    YES . THE FIRST TIME I PUT BATTERIES IN THE LIGHT CAME ON AND THEN RIGHT BACK OFF, THAT WAS THE ONLY TIME THE LIGHT CAME ON . THANKS FOR ANY HELP
  • cskierski May 11, 2010
    Did you put batteries in the bottom and swivel the light? The light automatically turns on when turned correctly.
Same problem, tried flipping it every which way with no luck - both the light itself and the arm that hold it. Finally, when trying to change the batteries, I noticed that they battery housing was odd: usually the positive end of the battery is against the node, and the negative end against the spring. This is true for one of the batteries, but for the other one has to turn it backwards, so that the positive end is against the spring. This is the only time I have seen a battery go in that way, and so naturally I had not looked for -/+ labels, but had just put the batteries in the housing in the way one would assume they go. When I changed the one around (and it was labeled that way), it solved the problem and the light came on. I don't know if I just got lucky, but you might as well try and see if it works for you.
Posted on Dec 19, 2010
I had this same problem...I spent about a half and hour messing with bulbs and batteries, and then my 9 year old finally figured out that all that we had to do was turn the light side up (to face to bottom of the black plate) and it comes on automatically. When turned down towards the feet of the microscope, it shuts off. Hope this helps!
Posted on Dec 31, 2008
All of the sites where you can download instructions or manuals for Vivitar products do NOT have the Vivitar 900x Microscope included. Where can we find instructions even on how to use any childs starter...
The best way might be to go to the manufacturer them selfs and contact them to see if they can send you the info you need there website is www.vivitar.com hope this helps -SuperRichard37
Feb 08, 2010 | Vivitar 900x 28-piece Microscope Set
Need replacement part for my sons vivitar microscope set
You turn the light on by LITTERALLY turning the light on it's hinges. It swivels and when the light is in it's downward position (with the little light bulb pointing towards the ground) it is off. When you flip it over (with the little light bulb pointing towards the the veiwing platform) it should turn on.
If you look closely, you'll see the metal-to-metal contact pieces that trigger the light to come on.
Dec 31, 2008 | Vivitar 900x 28-piece Microscope Set
What are all the tools used for?
go to thehandyhandyman.com he will be glad to help you
Dec 26, 2008 | Vivitar Microscope Set From 100x 400x 900x
Vivitar 900x  28-piece Microscope Set Logo
309 people viewed this question
Top Vivitar Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Vivitar Toy Expert? Answer questions, earn points and help others
