Question about Sharp LC-32SH20U 32 in. LCD HDTV
Blue screen, no video, but has sound
My sharp lc-32sh20u tv has lost its video.the sound is still there, but all i have is a dark blue screen. the remote still changes channels but no video. any help please ? jim
  • tnm_mills_12 Dec 08, 2008
    also when you first turn it on the screen starts off as white with a black stripe across screen, then the screen starts turning black from left to right. then when screen is full of black it becomes a dim dark blue
    no didnt help, but i appreciate the try, thanks
Blue screen no video but has sound
Posted on Feb 03, 2009
    Problem Solver:
  • 8 Answers
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Posted on Dec 08, 2008
No video with the vga cable
Have you installed the driver of your TV into your computer? Check if it has a driver dvd or cd. You can also try scanning your computer with radarsync to make sure that the drivers (video driver) are up-to-date.
David
Jul 08, 2013 | Sharp LC-32SH20U 32 in. LCD HDTV
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp lc 32sh20u when power on displays "please wait" and the screen within a split second or 2 disappears to a black screen. THe power light is still green or on. Audio still works. trying touchingthe...
WELL FOLKS I just FINALLY found what I have been searching for, I own a Sharp LC 32SH12U LCD TV that has begun to show problems with it's picture, Now it's sound is great no change..But it has gotten to the point that when i first turn it on all I get are three or four bright WHITE lines on the right side of the screen. They are a bout one third from the very corner of the screen.After it warms up for a while, MOST of the time it will just pop up and go to working just fine, that is what was giving it away to me that it HAD to be a something generally easy to fix, And in all of my searching I FINALLY found what I was looking for..Rite here on FixYA.com...There it was right thre in PLAIN ENGLISH..(( The T-CON BOARD )) Timing Control or LCD Controller..Board. on teh LCD panel Assembly, It transfers the image signal of the TTL and LVDS signal to specific TFT but What you all really NEED TO KNOW is JUST what is going on with your TV set when the T-CON Board is going bad, And I am about to tell you....So her ya go.. If you TV has any of these symptoms Well then I can pretty much say that your T-CON Board is bad or going bad...OK..If you have A Scrambled Picture,LINES,multiple Pictures Color smears, blotches, Rolling Pictures after warm up, Blown Surface mounted Fuse No Picture, Very Dark Screen almost like there is no backlight....Folks if your SHARP LCD TV is doing ANY of thsi then you just may need to replace your T-CON BOARD!!!! Hey it beats buying a new TV RIGHT!!!! GOOD LUCK FOLKS!!!!! I have already bought my replacement T-CON Board, as soon as I get it and install it I will let everyone know how it went!! PLEASE CROSS YOUR FINGER"S AND PRAY THAT THIS WORKS FOR US!!!! Thanks Wade in Eastman Georgia...
Oct 02, 2010 | Sharp LC-32SH20U 32 in. LCD HDTV
Sharp lc-32sh12u...no picture
It can be either the LCD panel driver board, or the worst case is bad LCD panel.
Nov 18, 2009 | Sharp LC-32SH20U 32 in. LCD HDTV
Audio O/K no picture . Model Sharp LC-32SH12U. Thanks "Larry"
Check for a backlight failure by holding a flashlight on the screen at about a 30-degree angle, a couple of inches from the screen. Look at the area around the flashlight beam. If you see video, either your backlight fluorescent tubes are burned out or the inverter has gone bad. If you need tubes, search for "CCFL replacement" (CCFL = cold cathode fluorescent lamp").
Aug 10, 2009 | Sharp LC-32SH20U 32 in. LCD HDTV
Odor comming from lc42d77x aquos sharp lcd tv
LCD TV don't give off odours unless there is an electrical problem, like burnt plastic smells. Can you describe the type of odour?
Could be some kind of insect etc. that is traped inside and died.
Apr 22, 2009 | Sharp LC-32SH20U 32 in. LCD HDTV
No display on Sharp LC 32sh20u
blue screen,no video but has sound
Dec 18, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Aug 07, 2008 | Sharp LC-42D64U 42 in. LCD HDTV
No Video on Sharp Aquos LC-46D62U
Have you check all inputs as the HDMI inputs and the composit inputs are processed on a different bd?
Feb 26, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC-32SH20U 32 in. LCD HDTV Logo
771 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
