Printing on 3x5 notecards.
I set my settings in WORD to 3x5 paper size and click print. My HP photosmart printing says the paper is to small. How do i print on notecards?
    Master:
  • 461 Answers
Some printers have a slot in the exit tray to use for envelopes and cards, if yours does not it may not support printing of cards. Please provide the model number and/or check the HP website for information.
Posted on Dec 08, 2008
Out of paper error
The paper settings in the print driver must match what is loaded in the product. NOTE: These changes do not change the default print settings. The print settings return to default the next time the program opens.
  1. Open the document that you were trying to print when the issue occurred.
  2. Click File , and then click Print . The Print dialog box opens.
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
  5. From the Size is drop-down menu, select the paper size that matches the paper in the tray.
  6. From the Type is drop-down menu, select the paper type that matches the paper in the tray.
  7. Click OK , and then click OK again to print the document.
Nov 23, 2010 | HP Photosmart 8250 InkJet Printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
I'm trying to print some photos on 4 x 6 paper. i selected notecard paper size, but the printer keeps printing the 4 x 6 photo on 8 1/2 x 11 paper.
Are you telling the printer to use the smaller paper?
If it has 2 sizes it will keep using the last size used unless you tell it to change.
Sep 27, 2009 | HP Photosmart 3210 Printer
I can't print a letter from my microsof office word program. the printer works but when i try to print t6his letter i doesn't Hp photosmart c5280 all in one printer scaner copier , ineed and up date...
Check if the correct paper size is selected according to the letter size that you are trying to print,select custom size and give the specifications of the paper manually.
Open Solution center software on your PC, click settings>Printer settings, in the feature tab you have an option named Paper type, select plain paper and then click ok and close window and Solution center and try to print.
Sep 27, 2009 | HP Photosmart C5280 InkJet Printer
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
How 2print 8 x 8 inch paper, HP Photosmart C5180 All-in-1 printer
From the User guide:
Select the appropriate options for your print job by using the features available in
the Advanced, Printing Shortcuts, Features, and Color tabs.
Tip You can easily select the appropriate options for your print job by
choosing one of the predefined print tasks on the Printing Shortcuts tab.
Click a type of print task in the Printing Shortcuts list. The default settings
for that type of print task are set and summarized on the Printing
Shortcuts tab. If necessary, you can adjust the settings here and save your
custom settings as a new printing shortcut. To save a custom printing
shortcut, select the shortcut and click Save. To delete a shortcut, select the
shortcut and click Delete.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing. The user guide link: http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can I print pics smaller than 3x5
No we cannot print pictures smaller than 3x5. The minimum size itself is 3x5. For more information please open the below webpage to see the product specifications of C4100 series all-in-one.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652183&cc=in&lc=en&dlc=en&product=1141647#N1120
May 13, 2008 | HP Photosmart 4180 All-in-One Printer
8250 hp printer
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  4. Click Properties . The Printer Properties dialog box displays.
  5. Click the Paper/Quality tab.
  6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
  7. In the Type is drop-down menu, select the type of paper loaded in the unit.
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
Printing problems
check document paper size, sounds like you have changed paper size on print driver but what of the document you are trying to print? what size is that? is it still letter or have you set page size also to 4 x 6
Nov 10, 2007 | HP Photosmart A612 InkJet Printer
Word Settings for Printing Postcards
I found the fix!! Once you have your size settings typed into your page layout screen and applied to the document, click print. Once you select your printer, click on properties (or printer preferences) click on the features tab (the tab next to printing shortcuts) and go to the resizing options section. click on paper size bar and scroll down to custom. once in the screen, give the shortcut a name you'll recognize, type in your dimensions in the provided spaces click save. once you go back to the features screen, scroll back down to custom and select your shortcut that you just created and apply it to both the paper type and paper size. click ok and go back and click ok to print! Hope this makes sense..if not, go to HP's website and type in your product name, type paper mismatch in the keyword search bar and click ont the first link in the found section. It will give you the same step by step instructions....
Sep 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
740 people viewed this question
jasbo
jasbo
