WPSM54G Print Server on iMac
You had suggested a workaround to make this work on an iMac.  What is it?  Thank you in advance.
  • 611 Answers
I mac is operating system which apple company provide
Posted on Dec 13, 2008
I have a wpsm54g successfully connected to my router and 2 XP laptops that can print via the print server. A friend has a win 7 laptop that we want to connect to the print server but the linksys install...
go into the control panel and add a wireless printer, it should detect it on the network.
if this doesnt work try going on the website and locate the driver
Mar 06, 2011 | Linksys WPSM54G Print Server
How to add my new laptop w/vista to the print server
Visit: http://www.linksysbycisco.com/US/en/support/WPSM54G/download to download the software called (driver) and install it using the Quick Installation right below it.
Aug 16, 2009 | D-Link DPR1260 Rangebooster G...
Can't connect to WPSM54G after configuring it
hi sir,
1. first reset the printserver
2. make sure that the printer drivers are installed on the comp.
3. use a w/l comp on which we can go online
4. connect the w/l comp to the print server using ethernet cable and also connect the printer to the print server
5. put the print server cd into the comp and run setup.
6. make sure printer server is near to router and there is no firewall on the comp.
7. the setup will give the ipaddress to print server if not plz assign static ip on the printserver.
8. follow the wizard
9. it will ask u the w/l settings to enter. plz type the exact same n/w name and security password.and apply the settings.
10.after that it will connect u to the print server and u will be able to print if you will not u will find an error to open port.
11.you need to open standard tcp/ip ports for the printserver ipaddress that u have assigned.
12. if u dont knw, u can ask the comp vendor.
13. plz also confifm that the printer is compatible with ur print server.
thanx and regards
sukhiii
Apr 16, 2009 | Linksys WPSM54G Print Server
Cannot see WPSM54G wireless router after configuring it correctly.
It's pretty sad. This device doesn't support Mac and apparently it doesn't support Windows either! I expect a lot more from Linksys. It seems like this is a common problem yet they offer no clear solution on their web site. Do you think maybe Linksys is going out of business and isn't going to support their products anymore?
Apr 13, 2009 | Linksys WPSM54G Print Server
Useing Linksys wpsm54g with tcp/ip
that will depend on the IP address of the print-server and the network, specially if the printerver is not set to a static IP, you may get communication errors when you try to use or install the printserver.
you may try to set the PS to have a static IP address or you may use the printserver name instead of its IP address.
use custom settings then use "RAW" after that chnage the queue name to p1 or l1.
there are many work arounds for this kind of limited configuration, but i would strongly suggest you call Linksys Toll Free Tech support for more configuration
Sep 30, 2008 | Linksys WPSM54G Print Server
Any way to make this work with an iMac?
on the LinkSys product overview it says that the WPSM54G Wireless Print Server requires windows XP or 2000 to install correctly. This doesn't necessarily mean you CANT use it with an iMac, but doing so becomes slightly more of a pain in the rear than it's worth. For more information look up the print server model on the LinkSys webpage. There is a potential solution available there but the directions are unconfirmed so i will not link them here.
Jun 18, 2008 | Linksys WPSM54G Print Server
Installation wizard does not locate the WPSM54G
hello!
what is the model number of your printer? if your setup cd is not detecting your printserver, try the ff:
-- while pc and printserver connected to the router and your printserver connected to your printer. try to reset the printserver for 30sec. Is it printing? If yes, do you see any IP address on the print out
-- If no, unplug the power for 5 seconds and plug the power back in of the printserver then try again to run the setup cd. you may also check your routers dhcp server table if its detecting the printserver
-- if printserver still not detected ty to connect printserver directly to your computer
-- search if you have bi admin utility on your setup cd and install it on your pc
-- manually assign static ip address on the printserver using the bi admin utility and on the pc
-- if successful, connect printserver and pc back to the router and check if you can ping the ip address of your printserver
May 01, 2008 | Linksys WPSM54G Print Server
Network printing
I am afraid, PSUS4 is an older model of print server , which supports only ordinary printers. All in ones are not supported by PSUS4. Linksys have other print server which works with all in one printers. The model number is WPSM54G. Probably you can try that. Also, if the PSUS4 is less than one month old, you can get it replaced with the WPSM54G from the stores itself . The WPSM54G can be used as wired as well as wireless to the router. If you want to use the PSUS4, you may need an ordinary printer like Office jet or laser jet with USB 1.1 version.- Thank you
Oct 26, 2007 | Linksys (PSUS4) Print Server
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
