Question about Whirlpool Washing Machines
I have a Whirlpool front load washer wfw8400tw02. I have had 2 service calls to checkout the out of balance condition. The first tech moved a drain hose inside the machine. The second one tried leveling the machine and made it worse. I already had it level before both tech were out here. Still has bad noise like it's hitting inside. I think the the tub spindle is bent. Bought new in July 2008 serial number is HLW1382740. Can you help as whirlpool hasn't.
    Genius:
  • 1,028 Answers
Being level is not quite as important as being solid on floor or on solid floor..if on a pedistal remove bottom drawer and be sure all mounting screws are tight ..with drawer adj all legs up until they are up tobottom of pedistal ck washer by trying to rock if movement detected adj FRONT feet only as much as needed to reduce motion ..same applies without pedistal if is a noise issue more than an unbalance issue suspect shocks supporting tub try removing bottom panel and being careful allow unit to run and try with one hand to isolate which shock..changed 1 friday
Posted on Dec 08, 2008
The washer will not spin
It could have an object in the pump. Your tech sheet will help. Remove the kick plate to find the the tech sheet and clean out the pump filter. Here's How
If yours is an affinity model then you might have a clogged hosethemobilian_903.jpg
Affinity service manual
If it is a duet click here
Jan 16, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool front loader washer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Washer will not spin tub
heatman101
Nov 01, 2010 | Whirlpool LSR9434PQ Top Load Washer
My Whirlpool 8280867 won't drain. How can I fix this? steve
heatman101
Sep 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer is flashing Ld, the water isn't draining and it's not spinning. Is is something I can fix or do I need to call a repair service?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool Calypso Top Load Washer isn't draining or spinning. What can I do?
heatman101
Sep 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Have a whirlpool front load duet. Will not rinse or spin
heatman101
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 6AWM8143 Front Load not starting spin cycle
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Problem
the shocks have been redesigned, however that does seem to be an awful coinicidence that it would happen right after( sounds more like an unbalanced load your trying to wash, perhaps only a few items?? or maybe all light clothes and a heavy item throwing off the balance, but as far as the mildew smell, make sure your using HE detergent, specifically designed for the frontloaing washers, and use this product to clean your machine. www.affresh.com
May 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal De
