Question about Kirby G6 Bagged Upright Vacuum
Kirby Sentria doesn't pick up visible dirt
My Sentria obviously has suction - if I tilt the head up, the carpet comes with it. However, it doesn't pick up even small tufts of dog hair, small bits of yarn, bits of vegetation. The carpet underneath looks cleaner - but there's still stuff on it. Surely I shouldn't have to pick that up by hand?
I am using it on a low-pile area rug with head in position 1 or 2.
Also, how do you remove the bag? I know to rotate the bag at the top, but gentle or otherwise, the cardboard bends but the bag doesn't budge,
  • Anonymous Mar 17, 2014
    there seems to be plenty of power but the cleaner does not pick bits up from carpet
  • 357 Answers
YOUR BELT IS NOT CONNECTED CORRECTLY...USE MY GUIDE TO FIX IT...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Posted on Jun 28, 2009
  • 24 Answers
To double check if the brush is rotating, there is a green led light on the top right of the power head. If the light illuminates the brush is rotating, which also means the blower is working. As long as the bag is clean, there are no obstructions in air flow and the brush is rotating the vacuum should be working fine. If the brush is not rotating the belt is either broken or not engaged. It sounds like the brush is not rotating, which is a very easy fix.
Posted on May 31, 2009
  • Kirby Expert
  • 324 Answers
As far as picking up - I suspect that your belt is not properly installed. Watch the video manual HERE. in the first halve of the video there is an instruction how to properly instal nozzle.
You have to turn the bag about 30-40 degrees countercloclwise so plastic protrusions on the tube top adater (ones that keep bag attached to the tube) will allign with cuts in bag cardbort so you can pull the bag off the adapter. If you will take a look at the new bag - you will see what I am talking about.
Posted on Dec 10, 2008
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
There isNo suction on Kirby sentria
  1. Put the hose and see if suction is good. If it is - you may have had nozzle installed wrong or brush roll may be worn out (bristles must be sticking out of the nozzle by about 1/8 of an inch).
  2. If there is no suction with the hose either - check if bag is not overfilled to the point where dirt is blocking the fill tube hole.
  3. If two above are fine - something must be blocking the air passage from the fan to the bag. Check for clogs in the fill tube (tube inside the cloth bag) and mini emptor (bag bottom plastic part) and also see if there is something blocking the exhaust on the vacuum. You may not even see it so use a piece of wire. Once I found a sock there and it was so close to the fan that I could not see it in the hole and was only able to get it out using a homemade hook made from a coat hanger.
how to check for a clog in your Kirby
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 28, 2014 | Kirby Ultimate G Bagged Upright Vacuum
How do I fix suction on kirby sentria upright vaccum
www.goodvac.com
1-800-775-6586
May 20, 2014 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
No suction from my kirby sentria
I just took a stiff piece of coax cable, and took the bag off where it attaches to the main unit, and took the head off ( the part with the brush roll in it) AMD cleaned every thing really well, turning the spindle for the fan while " snaking" it and pulled out a baby sock! Ta-Da! Works like New.
Apr 29, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I am trying to assemble the shampooer part of my kirby sentria
Hi There,
Here's a link to a very helpful video that will walk you through step by step on how to attach the carpet shampoo attachment to your Kirby Sentria.
If you ever need to purchase some Kirby Carpet Shampoo, please visit the link below to our website. You may use coupon code GVC5 to save $5:
Kirby Cleaning Supplies, Including Shampoo, Stain Removers, and more.
Here's the link to the video instructions on how to convert into a carpet shampooer:
Video Instructions On How To Convert the Kirby Sentria Into a Carpet Shampooer
If you have any further questions or concerns please feel free to use the comment field to ask, I'm always happy to answer any and all follow up questions.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me, this is greatly appreciated by the Fixya Community Experts when they're able to help you solve your problems.
Thanks again,
Chris Jones
GoVacuum.com
Jun 11, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Need Kirby Generation 3 Vacuum cleaner manual. Vacuum is not picking up dirt from floor. Seems to have enough suction to inflate the bag, but when you check the suction under the vacuum, there seems to...
If your brush roll is turning and your bag is not overly full, then the only other thing it can be is a clog where the bag connects to the vacuum. Turn the plastic part out away from vacuum and lift off to see if you have something clogging it. It would have to be something big, but not so big that it could not get past the fan. As a rule of thumb, KIRBY never clogs. I suspect that your belt is stretched out and your brush roll is not turning while on the carpet so the brush roll is just in the way rather than brushing your carpet to pick up dirt.
Jun 08, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My Kirby Ultimate G does not have enough suction to pick up pet hair. Is there anyway this can be corrected? I felt under the vacuum when it was running, the roller is running, but I felt very little...
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
With the hose on I have suction, with the carpet head not much
it looks to me u have something stuck in ur hose or in the carpet head....if u can loosen the hose use a broom handle and push it true....u may be suprized what u will find......good luck
Mar 28, 2009 | Kirby G5 Bagged Upright Vacuum
No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
Jul 07, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
543 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
