Question about Roper RAS8445KQ Top Load Washer
Amana NAV2330 Wont Agitate or Spin
Ok... Our washer stopped working. We found a penny lodged in the pump and the top of the pump was stripped out. We replaced the pump and the belt. Washer will fill, and go through the cycles and drain, but the agitator wont spin and the tub wont spin.
I watched it from the inside to see what was going on. It looks like the little white piece that is on the pulley is supposed to meet with the other little white piece that is on the bottom of the shaft, but they are not. The pulley spins fine, but it seems like the shaft should be moving up and down. When I press on the brake myself I can unlock to tub and spin it. When I spin the shaft myself the agitator spins.
  • 2 more comments
  • AKoch199 Dec 08, 2008
    We ran the belt around the pulley on the pump and to the pulley on the shaft. I did hook up the spring. I have even tried when the cycle is running putting more tension on the belt but that does not help either
  • AKoch199 Dec 09, 2008
    I double checked the belt last night. It wraps around the pulley part of the pump and than the pulley on the shaft. Than there is a pressure thing and when I connect the spring it puts more tension on the belt.
    Last night I ran a wash cycle. I pushed the bottom helix thing thats on the shaft up into the helix thing thats part of the pulley. It agitated fine. But when it went into spin cycle, the bottom helix dropped down and the tub still would not spin. Than when I ran the wash cycle again without pushing the bottom helix into the top one, nothing happened.
    What is supposed to be moving up and down to connect the helix's and to hit the brake? The shaft or the pulley?
  • AKoch199 Dec 10, 2008
    Ok first I want to say thank you so much for helping me.
    I understand what you are saying... kinda. I know that the two helix's kinda lock in with each other to create agitation. The bottom helix is fixed on the bottom of the shaft. When I put it into cycle, the bottom helix is about an inch and a half too low to lock in with the other helix on the pulley. Is the shaft supposed to be moving up at all? Or is my shaft too low? I can manually slide the shaft up so that the two helix's meet, and than it will agitate, but when that cycle ends, the shaft drops back down and then they are too far apart again.
    Again... thank you so much for helping me!!
    Ok. Well thank you very much for all of your help! I really appreciate it. And I will call a technician to take a look at it. You have been extremely helpful. Thank you for your patience!!
    President:
  • Roper Master
  • 2,651 Answers
I would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Posted on Dec 08, 2008
  • 1 more comment
  • Ron Coons
    Ron Coons Dec 09, 2008
    the white plastic "helix",(lowest plastic cam, under pulley. when spun one direction has no affect on hte upper half of pulley,brake locked unit agitates, but when the motor reverses, hte cam portion of the helkix should push up on the pulley and release the brake.thus "spinning" the tub.. perhaps the "cam" portion of the helix has worn through, not grabbing the pulley?(doesnt seem likely, sure wish i had a diagram of how the belt is wrapped around the pump, just seems like thats the issue)
  • Ron Coons
    the "shape" of the helix, is what applies pressure, one half is angled up to a point, and the opposite side of the pulley is matched the same. one direrction it simply moves around with eachouther, when its reversed, the helix and pully ride up on eachother, thus pushing up on the pulley, relesaing hte brake. this might be helpful, it was the only one i found, seems hes having the same issue
    http://www.youtube.com/watch?v=O89SkthTP...
  • Ron Coons
    Ron Coons Dec 10, 2008
    ummm no there is NOT supposed to be that much separation between them that is the bottom shaft of transmission, so i cant even think of a reason for that separation other than faulty transmission, but would hate to condem the machine for a poorly diagnosed issue, the tranny job probably 3-4 hundred dollars, and would require a tech for the simple reason of the specialty tool required to remove the tub seals and hub bolts.( not worth the hundred dollar investment in a one time use tool.) so although i normally would not do it i would recommend perhaps calling a tech to give at least a look at, dont know the cost of a service call in your area but the 50-80 may be a worthwhile investment just to see if your not missing something before condemning the transmission.
    And it is no bother, I choose to do this just for this reason ,,bugs me (and im sure you as well) as to why this wont work
Wont spin, drain or agitate
the transmission is either burnt out or the freaky looking belt that turns the pump is off. or the switch that tells the unit that the top lid is down sometimes comes loose cause some companies used a caulk like substance to keep the foot attached to the switch as slid away from where it is and the lid is not pressing that foot down to close the circuit and tell the tranny its safe to spin etc. You can fill with the lid open but not spin. There is a motor that controls all the spinning and draining or agitation and if something in their design is opening the circuit it wont perform those functions.
another idea is the timer motor isn't making contact and you might have to replace that..... there are tons of issues that can cause that.
Feb 20, 2014 | Amana Washing Machines
Wont spin or drain
Does the machine agitate if so this eliminates the motor coupling could be a bad timer place unit in spin if motor hums then power going to motor eliminates this check the drain pump it is white and attaches to the motor with 2 spring clips if there is something stuck in it or a bad bearing won't drain if a washer cannot drain it will not spin hope this helps.
Jan 19, 2014 | Amana NTW5400TQ Top Load Washer
Will spin but not agitate LWA40Aw2
Hi, it sound likes a belt. Some amana washers take 2 belts,1 for the spin,and 1 for the agitate. or some models spin rite of motor,and a belt for agitate. hope this helps. :)
Jul 07, 2009 | Amana ALW895 Top Load Washer
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Nov 30, 2008 | Amana 3.2 cu. ft. Top-Load Washer
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Wont drain or spindry-model 110.13212200 topload
To check the lid switch set it on spin. Should spin with lid closed & not spin with lid open. What is your problem ? (not filling ) ( not agitating ) ( not draining) ( not spinning ) it won't have an exit filter.
If the lid switch is ok it should agitate drain & spin .. The lid switch could stop agitate on some & not on others. If it is not draining it could be the pump. Sometimes a sock or something small can go down the drain and get in the pump & stop it up then it won't drain
like it should. Always say what the problem is like agitate or spin.
Hope this helps
Feb 02, 2018 | Kenmore 24432 Top Load Washer
Washer wont work.
I FOUND BROKEN BELT . HOW DO I CHANGE IT ?
Apr 27, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 80 wont agitate or spin
The Lid switch has gone bad. The new part is available from sears and costs $25.00.
Apr 14, 2008 | Kenmore 15864/15862 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
239 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
