Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52' I had the problem where the green light flashes 3 times. So i changed cp150, Cp 114, CL220 , And the flyback, the only one that looked bad was cp150. After reinstalling the board the tv came on and stayed on for a few minutes. then i shut it off. I came back 2 days later finished puting it back together and had a hard time getting it to come on. Then it came on and was on for a few minutes and a heard a pop and seen a flash in the screen. If i shut it off and turn it back on it will do that 3 times then shut off.
  • 3 more comments
  • xcr_amberg Dec 09, 2008
    checked both of them no fluid that i can see. I did find the sizzleing sound under the deflection board it was coming from a device directly behind the flyback maby CL031 it is a grey rectangle thing. i resoldered it and reinstalled the board. Now all I hear is a noise from the right speaker (If you are looking at the set) Green light comes on three times same sound all three times.
    Yes cp 150 was bad. I changed it as well as cp114 and CL 230. Are them the 3 that you are talking about changing together or did i miss one. Thank you for your help.
  • xcr_amberg Dec 10, 2008
    100uf 100v
  • xcr_amberg Dec 14, 2008
    cp 111 is a blue rubber coated device it says ARR,331k,2KV46 on it I did find 3 other caps that are green with gold there #S are cp120,cp130,cp135 all with the value 220uf 35v.
  • michaelisler Dec 14, 2008
    I HAVE THE SAME PROBLEM I LOOKED IT UP AND IT SAYS THAT YOU CAN REPLACE THE LAMP BUT ON MINES THERE ARE 3 BULBS IN THE FRONT PANEL. THE GREEN LIGHT BLINKS AND I HEAR A CLICKING SOUND WHEN IT COMES ON BUT THEN GOES OUT NO PIC OR SOUND.
  • RCA Master
  • 5,138 Answers
You could have a tube leaking fluid out go back ck all the Tubes see if any of them has leaked anyfluid out on to boards. pull front bottom off of TV so you can see them . Let me know what you finded also second ribbon connector make sure it is in good.
Posted on Dec 08, 2008
  • 3 more comments
  • ladywinn
    ladywinn Dec 09, 2008
    OK lets go back to the start you said that cp150 was only cap that looked bad was it bubbled up on top? The reason am asking is if cp150 is bad 2200uf 16v capacitor there is also 2 other capacitor you must replace when this one is bad they are 220uf 35v, somtimes one of them will be a 330uf replace all 3 caps ,let me do some more checking these sets can be a pain in the neck to fix sometimes,and heres another idea if you are sure problem is only in the deflection board then it may be cheaper to replace board call UED 1-800-648-6657
  • ladywinn
    cp150 cp111 cp114 are the caps ,most of the time all 3 are green with gold writing on them it is the capacitors value 2200uf 16v and so on.
  • ladywinn
    ladywinn Dec 10, 2008
    What is the value of CL230?
  • ladywinn
    wrong cap other cap will be either 220uf 35 v or 330uf 35v, some deflection boards have 2- 220uf 35v then others will have 1-220uf 35v and1- 330uf 35v these are values to chage 2200uf 16v ,220uf 35v, 330uf 35v.
  • ladywinn
    ladywinn Dec 14, 2008
    You have to keep in mind RCA made 26 different deflection board ,24 different SSB they all look alike and close enough boards but have alot of different connectors on boards so on each board cp numbers very. You still havent said how is the repair on your set ? Are you still trying to fix it yourself?
52" rca hdtv monitor power flashes 3 times after pushing it and tv does not turn on.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 10, 2010 | RCA R52WM24 52" HDTV Projection Television
Replaced cp150 @cp114 plus flyback. tv runs great but not full screen.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If you have already replaced two of them then replace CP 120: 330UF/35V/HF and post back if that makes any difference.
Thanks Rylee
Jun 05, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA d52w19. when I turn it on, the LED flashes 3 times and shuts off. Basically the same problem as everyone else. However, I changed CP150, CP120 and CP114 and still have the same problem. What...
if you replace the bad cap,s cp114 cp150,cp120 and still give you flashes 3 time you do have a bad flyback 21.40 for the flyback but in the same fix you see 3 fuse by the flyback hit them with solder thay is the power supply for the conv, borad.i work for quaker tv i seen a lot of that d52w19. you mite whant to look at the power wire that go to the front buttom con,t in front of tv if thay are pich in eny way the set will not come on. but you have a bad flyback.
Dec 07, 2009 | RCA D52W19 52" Rear Projection Television
Power light flashes 3 times then nothing
this sounds like the typical bad fly-back transformer that is also known as the high voltage transformer, n=-Not really a repair for a novice so unless you know all of the safety notices with this set please do not attempt this repair as why save 100 bucks for something that could seriously kill you!!!!!
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52 IN
Bad capacitors on Power/deflection board cp150,cp114,cp120 capacitor cp 150 2200uf 16v, cp114&cp120 220uf 35v
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback replaced
your flyback should still be good get the other parts changed out and go from there
Dec 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
193 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
