Question about Hotpoint HSS25GFP Side by Side Refrigerator
Water despenser stop working ice work on both setting give crushed ice
    Problem Solver:
  • 5 Answers
I had the same problem. I found the answer on this forum.
The water line could be frozen in the door. Need to 'thaw' your door.
Copy paste link.
Posted on Dec 10, 2008
Cannot get water out of front despenser but can get Ice
found that when I used the crushed ice option, the lines would freeze up. Cubes were ok. Take everything out, including the ice, and turn it off for about 12 hours. Then check to see if it works again. If not, wait a little longer to let it fully defrost. If it still does not work after 24 hours, then you might need service.
Jul 09, 2010 | GE GSL25JFPBS Side by Side Refrigerator
It despense water, but does not make ice
Either the water valve is bad or the icemaker is bad, assuming it is turned on.
Check the valve with the wires off with an ohmmeter.
If it shows continuity, the icemaker is bad.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
My ice maker is not despensing ice, but water works. It is a GE Monogram refridg. Water works, but when you change to ice, nothing happens. when it was acting up, all it would do is dispense crushed ice,...
Could you look on the bottom frame of your GE Monogram around the door frame and behind the fresh food section door seal for the model number? The problem most likely is in that control panel that you use to switch from crushed to cubes. Let me know, Sea Breeze
Jul 22, 2009 | Refrigerators
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
Crushed Ice only
I have a similiar problem. I have dumped the ice and started ice maker again. It make ice but will not despense ice cubes.
Apr 27, 2009 | Refrigerators
Sounds like you are not getting enough water into the ice maker tray. When the ice ejector removes the ice from the tray, it may be causing the ice to splinter which is the crushing you describe. The problems could be:
* The water inlet valve
* The ice maker water inlet is partially frozen in the freezer section
* There is a problem with the water line (kinked or partially obstructed)
* The timing mechanism for the inlet water valve isn't working correctly
Check #2 from the above list first
Mar 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice Dispenser
hi there,
check to see if you have a leak either on the inside or the outside of the freezer door.
check your icemaker line and see if anything is freezing up.
from the sounds of it, something is stopping the water flow into the icemaker.
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
54 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
