Question about Canon DW 100 DVD-RW Burner
Canon DW-100 1) Were can I find the manual for the Canon DW-100? 2) Can I play back a HI DEF. DVD burned with Canons DW-100 on my HI DEF. TV using a BLUE RAY DVD PLAYER ? Thanks gunter
Yes you can play a DVD burned with the DW-100 in Hi Def as long as you are using a DVD player that supports AVCHD format which is what the DW-100 burns. Most Blu-Ray players will support AVCHD.
Posted on Jan 18, 2009
Thanks, I think it works that way. gl
Posted on Dec 09, 2008
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
I am thinking of buying a Connon VIXIA- HF-MA300. Will the DW-100 burn directly from the camera ?
Connect the camera to your PC.
Connect the Canon burner to your PC.
Use free software (see: and search for "AShampoo Burning 6")
to read the files from your camera, and burn them to a blank CD/DVD disk.
Dec 12, 2010 | Canon DW 100 DVD-RW Burner
Canon DVD burner DW-100 and HG10 burn issue
You can not have any MXP Files in your play list or in memory. The DW-100 Can not burn these files. Once you delete/remove the MXP Scenes from the the Camera the Burner will work fine.
Dec 13, 2009 | Canon DW 100 DVD-RW Burner
Our Canon video camera will record in both HD and SD. We've recorded all of our video in SD so far and I burned some of it onto the Canon DW 100 burner and I can't get it to play on my DVD player. please...
You should burn your videos to a video format that should be compatible with your DVD player to get play. Some video formats will not be able to play to a certain DVD if the DVD player does not support it. You should burn your videos to VCD format to avoid problem because almost DVD nowadays have backward compatibility for all VCD movies. Hope this could help you..Please don't forget to rate me..:-) Thanks..
Nov 04, 2009 | Canon DW 100 DVD-RW Burner
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
Will the DW-100 DVD burner work with the HG-20 camcorder
I recently purchased the DW-100 for my HG-20. Works like a charm.
Some quick gotchas though...
People complain that Canon was not 100% clear about it's use. You can only burn standard definition (i.e. "non" hi def) DVDs if that's how the camera recorded it... I never looked to see if my HG-20 is capable of the old stuff, but basically the camera is sending data to the burner and there's no real conversion going on. Some Canon models record in Standard Def others do not.
Personally, I use the burner to backup videos onto standard DVD-R (or DVD-R DL) discs. The discs are burned in a Blu-ray compatible format. (but you get 4.7 or 8GB onto a disc vs the 30GB you'd get on a Blu-ray disc - but don't complain b/c the Blu-ray discs cost a fortune.)
If you don't own a Blu-Ray player you can connect the USB b/w the "camera & burner", and then the HDMI b/w the "camera & TV" and send the video from the burner, thru the camera, and watch on a Hi Def TV. (Complex but it does work and the picture quality is great).
Hop this helps.
Jan 31, 2009 | Canon DW 100 DVD-RW Burner
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
Hi. I bought a Canon HF100 camcorder. I tried to burn a DVD using a Sony VDR-MC5 via the USB connection. Unfortunately it did not recognise the Canon! If I bought the Canon DM-100 burner I believe it can...
I discovered that the USB connection only works with the Canon DM-100.
I was able to connect the composite cables (red, white, yellow) from the AV out connection of the Canon HF 100. This works fine. It now records on DVD - R; DVD +R:
DVD - RW and DVD + RW.
Hope this helps anyone else with this problem.
Aug 19, 2008 | Televison & Video
P3 not playing high def dvd
make sure your tv input is on the right selection
Dec 10, 2007 | Sony PlayStation® 3 (60 GB) Console
Open Questions:
Canon DW 100 DVD-RW Burner Logo
446 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
