Question about Malber WD1000 Front Load Washer/Dryer
Water in drum after turning off
I have installed a Malber WD1000 in my tennants apt. I bought it used on Craig's list. It seems to be working fine, moving through the cycles and draining after each one. The tenant says, however, that when they turn it off, it fill half way with water.
Is this normal? Do I need to have the hose do something to keep drain water from easing its way back into the machine?
She also said that it is not drying well, but I think that is more about her learning to using the dryer part better.
Any suggestions?
    Genius:
  • 1,028 Answers
Could be a leaking fill valve ..not shutting off good after shutoff
Posted on Dec 08, 2008
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
How do I get the Malber all in one washer dryer to dry hotter. It seems to be getting cooler and cooler. It didn't use to be a problelm. I nolonger have the manual.
There is a wire which connects to a connection towards the front of the drum itself on the right side which when the drum wobbles, comes off. When it gets loose, it may start to arc so that the spade connector needs replacing. In extremis the whole unit may need replacing. This seems to govern whether the heater elements turn on or not. If you put the connector back on, I'll bet the heater starts to work again
Feb 03, 2011 | Malber WD1000 Front Load Washer/Dryer
I have Malber WD1000. Hot water run through the pipe, but do not fill machine. How can I find and check the filter of hot water in machine
Hello. Just turn off the water and then remove the fill hose which goes from the water faucet into the back of the machine. Examine the entire hose and pay closest attention to the filter located at the end of the hose nearest the faucet. regards, Joe
PS - please rate my answer as helpful Thank you.
Feb 08, 2010 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000 won't hi-speed spin
check if the drum assembly is loose, but it seems like one of the mounting arms or shocks broke.
Jul 10, 2009 | Washing Machines
Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
May 25, 2008 | Malber WD1000 Front Load Washer/Dryer
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
New Malber wd1000...how do you unlock the dryer..picked up at store
TURN THE MACHINE OFF NOW. If the machine still has the transit brackets fitted (which is what I think your post implies), operating it in a wash cycle is likely to lead to severe damage to the machine and could be quite dangerous too. You can find a copy of the manual here: http://www.absak.com/pdf/manuals/Malber/WDman.pdf Before you use the machine again, suggest you look at page 2, and check that everything that should have been removed actually has been. Turning to the question you actually asked, failure to go into a tumble cycle isn't really the sort of thing that would normally associate with packaging having been left in place. Skimming through the manual, there are hints (see page 14) that you're meant to do some counterintuitive things to make the dryer work on this model - like keeping the "half load" button pressed in. Making sure "Spin Cancel" is out is a bit more obvious, but just as important. A.
Jun 22, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
134 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
