Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-air downdraft blower doesn't work
Is ther a way to clean the blower fan?
    President:
  • Jenn-Air Master
  • 2,651 Answers
Thiknin thats a sealed unit, however imn sure they got it into a housing so i guess if you lloked close enough ther ewpuild be a few screws to gain access to the fan itself and with it open a quailty degreaser should work wonders in cleaning it!
Posted on Dec 08, 2008
How do I find and test ther fan control on a 2010 chyrsler town and country
ARE YOU REFERING TO THE RADIATOR COOLING FAN OR THE A/C BLOWER MOTOR ?
Jan 20, 2015 | 2010 Chrysler Town and Country
How to remove lent and dust from the sides. What type of tool is needed to remove the two sides for cleaning.
ther are cleaning brushes out there. look like a stick with a brush head on it. they have them in hair cutting equipment.
Sep 29, 2013 | Lasko High Velocity Space-Saving Blower...
Blower fan for heat/air continue to run with key off?
sounds like closed circuit or a short because the egnition is a master shut down and if it gets through that then ther seems to be a short bypassing the egnition
Oct 13, 2012 | 1997 Buick Le
IN THE MIDDLE OF COOLING THE AIR CONDITIONDER ( OUTSIDE UNIT) STOPPED WORKING AND THE BLOWER MOTOR CONTINUED TO RUN PUSHING AIR THROUGHT THER HOUSE. THE THEREMOSTAT CONTROL WILL NOT SHUT OFF THE...
make sure your thermostat is not set run the fan,
is there an auto/on switch on the thermostat subbase?
if so then switch it to the auto position
Jun 17, 2011 | Heating & Cooling
I have a 2008 Toyota Tacoma. The interior fan make a annoying ticking noise on low speed but its not noticable upon turning it to a higher speed.
ther is probly leaves or some trash in the blowermotor you will need to remove it lower righthand side of dash just 3 or 4 bolts the clean it out
Feb 09, 2011 | 2008 Toyota Tacoma
Air condition not blowing
not cold? may need recharged. fan not working? check fuse, check with a test lite at the blower motor connector to see if ther is power with the key on and blower on high, if you have power and no fan, blower is bad. if no power switch and wiring will need to be checked and you should probably take it in somewhere
Jul 07, 2010 | 2002 Jeep Liberty
The Blower fan inside the freezer stopped working. What is wrong?
simple things first it may be the door sw . if not then ck the fan itself it may have burned out . but make sure ther is power going t fan . you can use a test cord or a ohm meter to do the test .. **** ,,
Jan 19, 2010 | KitchenAid KSSC42FMS Side by Side...
My microwave comeson but food dosant get hot? I looked thers two blower wheels in upper back that doesn not come on but the blower on the side does?
the blower with two wheels hav nothing to do with your problem / the single blower cools the mag . and thats ok . no cooking is caused by no hi voltage like a bad cap or diode. most common. and sometimed the mag itself . the door switches can cause this but if the single side fan is going then there probably ok . I think its a hi voltage problem. ****
Jan 10, 2010 | Frigidaire FMV145K Microwave Oven
How do you clean a Lasko® High Velocity Blower Fan w/Remote
you need to dismantle the fan,
the top back pry off.
then you will see screws.
Aug 01, 2009 | Lasko High Velocity Space-Saving Blower...
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
652 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
