Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore ~ bad smell upon first use of broil function
Hi: I used the broil function (on hi) of my sears Kenmore gas oven. As soon as I turned on the broiler to heat it up, it smelled horribly, a smell almost like melted plastic. The smell has lingered for the past 2 days. Any thoughts on what might be causing this or how I can get rid of the smell?
  • 4 more comments
  • kwoolf Dec 08, 2008
    I am experiencing the exact same smell now -- except that my Kenmore is an electric model.
  • carlene98 Dec 11, 2008
    I have a new GE gas range and the smell is awlful, burns your eyes and lungs. It also smokes like crazy when self clean or broiling. Sears repair guy says its normal and if I had a exhaust fan that was plumbed out we wouldn't notice it as bad. So what he said was no problem. But this is really bad. What can I do?
  • Anonymous Jan 09, 2009
    We've used our new Kenmore electric oven several times but it still has that awful chemical smell when using. Does anyone have a suggestion how to eliminate the smell?
  • johnkasal Feb 04, 2009
    My new Kenmore gas range's oven stinks, too. The flames are so high from the oven that they come up threw vents in the lower oven perhaps 5 inches. It leaves black soot residue from just leaving the oven on a few minutes. It hasn't been used for baking,yet. Should I take it back to Sears or see about my one year guarantee. I do not feel it is safe to use the oven. It would set on fire anything on the lower shelves.
  • pet440 Feb 20, 2009
    I have the exact same problem with my oven. When I turn on the oven it smells like burnt plastic and the oven flame is way to big. I am using LP and did the conversion myself EXACTLY as the owners manual suggested. I'm wondering if the gas regulator is no good from the factory...
  • Anonymous Feb 22, 2009
    Same problem. Open all the windows and doors to outside, let it burn off for 15 minutes. When done, open oven door to get more smell out. you might have to go through this process 2 or 3 times. The chemical smell is toxic, so go outside for awhile.
If you pull out the drawer at the bottom of the stove, there is a brass fitting that needs to be tightened with a 1/2" wrench.
Posted on Mar 11, 2009
  • Kenmore Master
  • 2,651 Answers
Do you perahps have LP (tank gas delivered to home) and unit set for natural gas?
Posted on Dec 08, 2008
When I turn on the broil function in the top oven, the bake igniter glows. I checked the voltage in the wires to the broil igniter and there is 0 volts. Is this a bad component on the ECB or can the ECB be...
This is probably a problem with the wiring outside of the control. To confirm this, check for continuity on the bake and broil relays upon activation of the broil function. If the the broil relay activates and the bake relay does not then your problem lies outside off the control board. I am familiar with troubleshooting Maytag appliances as I work for a company that repairs appliance timers.
Mar 20, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a Kenmore gas range and the oven is not working. I do not hear any click (igniter) and I do not smell gas when I turn it on. The burners on top work fine. Any suggestions
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Dec 27, 2010 | Kenmore Ovens
I have a Kenmore gas range that doesn't light right away when I put the broiler on. I can smell the gas going to the pilot but it takes too long for the flame to light. Sometimes if I cancel the broil...
It seems to me that it is a bad thermocouple. It costs about $5. It senses the pilot flame and then tells the gas to turn on full. BUT if it uses an electric igniter that in itself is the gauge to tell the gas valve to turn on full. And that could be about $30 or more.
I am only slightly confused because you say gas range, but the broiler function is in the oven. So that is what I am believing what you are describing in your problem
Mar 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
I have a Kenmore oven with no directions. We cannot get the broiler to work. Can you tell us how to do turn it on?
Here's the manual for your oven, based on the model number you provided.
If this isn't your oven, use the following link to enter in your model number to get the correct manual, free. (click on the manual tab)
Hope you find this Very Helpful and best regards!
Here's how to use the broil function of your wall oven:
Press the BROIL pad. (This will
automatically set HI Broil).
lb. While the set indicator is flashing
in the display, press the BROIL
pad again if you prefer to use
Lo Broil. Use Lo Broil to cook
foods such as poultry or thick
cuts of meat thoroughly without
over-browning them.
2. Press the START pad.
3. When broiling is finished, press
the CLEAR/OFF pad.
Aug 28, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Bottom oven burner will not light
If your Kenmore is like most Whirlpool-built gas ranges, surface ignitors similar to those used in gas dryers are used. These devices have a conductive path fused to a ceramic substrate and are common failures. There are separate units for bake and broil burners.
Check the Sears website under the 'Parts' subsection and enter your range model number. This should bring up a choice of things to do and if you ask for the illustrated parts breakdown, you can see where the ignitor is located, get its part number, and generally order from that same site.
It's mildly disturbing that the range continues to allow gas to flow unignited.
Feb 07, 2009 | Kenmore 75012 / 75014 Gas Kitchen Range
Burners & Broil work but Oven burner does not!
HI thanks for your question. the problem is with the bake igniter. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 24" built-in oven wont heat
Sep 12, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
2,522 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
