Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Removal of boot.com virus from external hard drive and USB Stick
Recently I contracted the resycled/boot.com virus. It is a small program that is very annoying. It provents you from accessing your hard drives through My Computer. Using Malwarebyte's Anti-Malware I was able to remove the virus from the hard drives built into my computer (laptop) but boot.com has spred it's self beyond my computer. It hopped onto my 500gig external hard drive and my 1 gig USB stick. I took the instuctions from this site www.avalon5.com/science-and-technology/technology/how-to-eradicate-bootcom-trojan/ and it worked on my built in drives. Using Malwarebyte's Anti Malware I sucessfuly removed boot.com from my internal hard drives. I went to use the Malware program again for my external hard drive and USB but no such luck. If anyone can help, please do so. Thank you
  • Anonymous Dec 28, 2008
    Similar problem has been detected in my PC.
Silakan baca di >sini<
Desi Vibes
"boot.com" is a virus which attacks the hard drives & the hard drives could not be opened by double clicking. In hard drives after enabling viewing hidden file u can see some "autorun" file & a file named "boot.com" which cannot be removed just by deleting.
Here’s the REAL way to clean this off your system. You should do these steps after a fresh reboot in safe mode.
1) Navigate to the problem drive(s) via the Explore option.
2) Click on TOOLS -> FOLDER OPTIONS
3) Click the button which says ‘Show hidden files and folders.
4) UNCHECK the following boxes:
Hide extensions for known file types
Hide protected operrating system files
5) Find and delete the autorun.ini file and the resycled folder on the root directory of all affected drives.
6) Check “c:\windows\system32\dllcache” for boot.com file and delete it if present.
7) Check “c:\windows\prefetch” for boot.com file and delete if present.
8) Delete all files from c:\windows\temp
(Some files may not delete, that’s ok, they’re in use by the system and not virus files.)
9) Delete all files from c:\Documents and Settings\[USER PROFILE]\Local Settings\Temp
(Again, a couple files may not delete, don’t worry.)
10) Run Regedit
11) Make sure you are at the very first entry of the registry hive. (My Computer should be hilighted) then click EDIT -> FIND
12) Search for “boot.com”. If it finds an entry, delete it. Keep hitting F3 until you’ve deleted all instances of boot.com in the entire registry.
13) Scroll the left column back up to the top and hilight the My Computer again at the top of the registry hive.
14) Click Edit -> Find again and search for ‘resycled’ and repeat as in step 13, deleting the entries as it finds them.
15) Close registry editor and try opening the infected drives. They should work now.
Worked for me at least.
Posted on Apr 16, 2009
How to remove resycled/boot.com
<a rel='nofollow' href="http://www.tips29.com/2009/01/how-to-remove-resycledbootcom.html">http://www.tips29.com/2009/01/how-to-remove-resycledbootcom.html</a>
Posted on Feb 17, 2010
    Problem Solver:
  • 15 Answers
Hi, you can remove these virus by searching the boot.com in regedit and delete the entry. then you need to delete resycled directory and autorun.inf from each of the drives. If it shows access denied, use attrib –h –a –r –s <file name> in command prompt. and then delete it.
Posted on Dec 19, 2008
    Scholar:
  • 69 Answers
There are many things you can do to take care of this problem, the things that i would suggest you have already done. May i reccomend a reformat, which is something that needs to be done regularly anyways (every 6 months or so).
you see when you do contract an annoying virus like the one you describe, just simply trying to remove it is (in my experience) an excercise in futility due to a vast quantity of files and directories that this particular virus can hide in.
for all y cleints i would advise the same as i do here. backup your stuff and reformat everything because even with the solution you have found or the drives that you fixed i can almost garauntee the virus is still just waiting to infect again.
just my 2 cents
Stellyx
Posted on Dec 08, 2008
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
When connected it says hitachi cannot be modified
It sounds like you have some viruses and malware messing with you.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Aug 17, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
Folders becomes shortcuts on my hard drive and cant open
Jul 13, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to remove virus on Toshiba external hard drive
I assume you don't have an antivirus program installed. Go here:
http://majorgeeks.com/download.php?id=29&sort=7
Download, install and run these FREE apps and any other apps you feel
might help:
1. Avira Antivirus or Avast Antivirus
2. Kaspersky Virus Removal Tool
3. Malwarebytes Anti-Malware
MalwareBytes is here:
Just make sure to select your external drive so it's included in the scan.
May 22, 2012 | Computers & Internet
Hi, i have the ramnit-g virus on my samsung nc10 which is spreading itself all over my laptop and causing avast to constantly block the contaminated files, which is causing most programs to fail, and...
The Samsung NC10 can boot from a USB memory stick - you may have to press the F12 key to select to boot from USB rather than the internal disk drive....If you go to http://www.avg.com/gb-en/avg-rescue-cd you can download a copy of the AVG Rescue CD which comes in 2 versions, one for CD and one for USB - download the USB version and follow the instructions on the AVG web site for how to put this on the USB memory stick.....Boot the netbook from the AVG USB memory stick and use that to help remove the virus infection.
Apr 05, 2011 | Samsung NC10-14GW Notebook
I joined another internet cafe in cambodia and hooked up my USB drive Lacie Rikiki 500Gb and the McAfee OAS on the host computer reported it found a virus in it and deleted it. It was probably a boot file...
The computer at the Internet Cafe' probably was virus-infected, and the computer-virus wrote a computer-virus onto your USB memory-stick.
Just click "cancel" to that "which program" prompt.
Then, open "My Computer", and right-mouse-click on the icon for the USB device, and click "Explore", to view the files/folders.
Mar 17, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
My laptop suddenly will not recognise the seagate device,
Download "Testdisk & PhotoRec 6.10" from www.download.cnet.com
and follow the instructions. TestDisk is a powerful data recovery utility. It was primarily designed to help recover lost partitions and/or make non-booting disks bootable again when these symptoms are caused by faulty software, certain types of viruses or human error (such as accidentally erasing your Partition Table).
Once you install the program, you can find step-by-step instructions in google. This program is really easy to use and will fix your hdd.
Feb 27, 2010 | Seagate Free Agent Go Small 12 GB USB...
C:\resycled\boot.com is not a valid win 32 application.
I just had this problem and went to a few forums for answers.
Update your anti-virus program and restart your PC in safe mode by repeatedly pressing the "F8" key upon restarting.
When in safe mode, use your anti-virus program to scan your computer. When the scan is done it should tell you if it found anything that could be bad for your system.
When scan is finished, go to My Computer - Tools - Folder Options - View
When in "View" click on the button that says "show hidden files and folders". Select the "apply" button, then "OK".
Now, go to your infected drive (the one you cannot access) and "right-click" the drive followed by "open".
You should see the hidden folder "Recycler - resycled - Autorun.ini"
Select the files and then press and hold the "shift" and "delete" keys at the same time, then press the "enter" key. Restart your computer, and you're done. You should now be able to access the drive that had a problem.
If you do not see these files then chances are your anti-virus may have already taken care of the virus affecting your computer.
hope this helps
Jan 14, 2009 | Tablets & eReaders
Hi, recently i had virus in my comp called win32.worm.autorun.MQ i restored my windows through restore after cleaning up when i click on my drive it gives me error saying "resycled\boot.com is not valid...
This is a solution i found at another site that i think could help you with your probem
Hi
If you still need help with this please do following:
Download and install TrendMicro HijackThis
* Once installed open HijackThis by clicking Start > Programs > HijackThis and click the button labeled
Do a system scan only
* Click the scan button in the lower left hand corner of the interface and HijackThis will quickly scan your system.
* Once the scan is complete the scan button will now read save log. Click this button to save the log file to your PC. Once you select where you would like to save the file it will open in your systems default text editor. Typically this application is Notepad. Post the log here.
The link:http://www.techsupportforum.com/security-center/virus-trojan-spyware-help/hijackthis-log-help-inactive/306207-resycled-boot-com-not-valid-win32-application.html
Please let me know if you need more help with this problem
Jan 06, 2009 | Computers & Internet
Win32
well it is a virus
they incorporate with your disk and when you click on them the virus function become open
left click on the drive like d and then search for boot.com
you will see a file will appear
delete that file
or try to scan with your antivirus
do as early as possible because it will spread to your all drives.
Dec 12, 2008 | Microsoft Office Xp Professional Full...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,347 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
