Question about Acer Aspire 5100 Notebook
Batery lamp always on
The battery led diode always light red (charging) even the battery source is full. Usually after charging of 2 hours the led diode light green. Can i set something manually?
    Novelist:
  • 166 Answers
No sir, u can't set anything manual in that. Its a hard wired program and can't be re-programmed electronically.
Posted on Jul 21, 2009
Why does my ryobi 12 v battery charger light always staay red even after 6 hours of charging a battery ,never turns green
Sounds like you may have a bad battery. Does the batery seem to have a charge at all?
Nov 11, 2013 | Drills
Two red flashing led lights flashing. Constantly get the same problem fix and am tired of this problem had 4 controlers replaceded and several other things done almost $10,000 dollars done last year alone...
The 2 flashing red lights indicate a low battery. Did you have the batteries replaced? and did you have the charger checked? The charger could not be giving you a full charge or you didn't charge the batteries correctly. It takes about 9-10 charges to bring the batteries to 100% operating capacity. Always charge the batteries before using after installing new ones and then charge nightly when you sleep. When you get up in the morning the batteries should be fully charged and last all day. Never charge more than 12 hours and always store or put up fully charged Hope this helps and sorry that no one can seem to help you except spend your money needlessly
May 25, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
I have a question about the JDSU battery pack. i have an HST 3000 battery pack. The connector for the charger was broken, i replaced the connector and the batteries. when i charge the unit the red LED is...
Had a similar problem, it shouldn't take that long to charge. Try reseting the battery gauge, you'll find this under Power management. Only reset when you think the battery is full.
Feb 05, 2010 | Computers & Internet
When I charge a battery, the red light on the charger comes on but never switches to green and I dont know how long I need to charge each battery?
the green light or LED indicates or sign the the batery you are charging is already full,.so if it doesn't happen to switch ,it means that your baterry is weak and can not reach anymore the amount of current or amperes needed thats why it cant go to the highest peak of charging just like when it is new.Replace your batery and the green light will switch again if it is fully charge.
Nov 22, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Acer aspire one battery light flashes orange. When booting after a few seconds it shutsdown. Now all lights stay off. Can this acer netbook work without batery ? It doesn't seem to charge the batery
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
Nov 14, 2009 | Acer Aspire One PC Notebook
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Batery problem
I would call the manufacturer. Depending on your battery and what you do on it, that may be all of the time you get out of your battery. I have a small laptop and even on a full charge, I can only get like 2-3 hours of use.
Apr 27, 2008 | HP Pavilion dv6000z Notebook
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Acer Aspire 5100 Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
