New Hard Drive
Hi I have an Advent 7088
CPU AMD Sempron Mobile 2800+ BIOS AMI BIOS. Press DEL to enter Chipset ATI Radeon Xpress 200 Memory 512MB 200pin DDR-333 SODIMM (2 memory slots. Max 2GB) Hard Drive 60GB CD Drive DVD±RW Screen 15.4'' widescreen TFT (native resolution 1280x800) Video Card ATI Radeon Xpress 200M IGP (128mb) Sound Card Realtek AC'97 audio
The hard drive is st96812a, and needs replacing, can you advise me on how to upgrade it, and what you would suggest I upgrade it to. Thank you.
  • 50 Answers
Hi you can buy any 2.5" ATA harddrive .doesnt matter what make you buy them can get on Ebay, and which ever size you want,ie,80GB,100GB-
you will need a copy of windows though to install the operating system
Posted on Dec 08, 2008
Advent t9610
By pressing DEL can you enter the BIOS setup screen? If so, can you see the hard drive designated? It is usually in the initial screen where it lists all recognized peripherals, including your DVD drive and (hopefully) your hard drive.
Mar 14, 2014 | Computers & Internet
Need help figuring this out. Complex!
Configuring your computer to boot from a USB drive allows you to boot into a separate operating system stored on a bootable USB drive.
This is handy when needing to troubleshoot a computer or access the hard drive without booting into the main operating system.
In order to boot from a USB drive, your computer's motherboard and BIOS must support USB booting.
If they do, then a simple tweak to the BIOS settings is all you need to do.
Shut down your computer and allow it to completely power off.
Insert your USB drive into an open USB port on your computer.
For ease of access, try to insert it into a front port if you have one.
Turn on your computer and enter the BIOS menu.
When your computer first boots, the manufacturer's logo will appear on the screen.
On the bottom of the screen is a note telling you which button to press to enter the BIOS.
Quickly press the button to enter the BIOS menu.
All manufacturers are slightly different, but some common buttons for entering the BIOS are F2, F10, F12, ESC and DEL.
If you are unsure, refer to the owner's manual that accompanied your computer.
Use the arrow keys to scroll down to the boot device menu.
It will be titled differently on different computers, but look for something like "Boot Order" or "Boot Devices."
Press the enter key to enter the boot menu.
Scroll down to "USB Drive" and set it as the first boot device.
Exit out of the BIOS menu and reboot your computer.
When your computer boots up it will boot from the USB drive first.
WeetHetBoot from USB Flash drive
http://www.weethet.nl/english/hardware_bootfromusbstick.php
May 13, 2013 | HP Compaq Presario SR1830NX PC Desktop
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
Advent 7083 drivers
You can go to the following site for drivers for your Advent 7083
http://support.thetechguys.com/layout.aspx?ID={64e249d4-f085-47e0-a64a-5fb0a1c0b111}&CatID={2d964229-bedd-400a-ae44-316a77a38764}
Since the 7083 is basically a rebadged ECS 331 ( you should see 331 printed on the underside
of the laptop ), you can also go to this site as well
http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=562&CategoryID=3&MenuID=58&LanID=8
See the below information about your laptop.
Advent 7083 Laptop Specification CPU AMD Turion64 MT-30 (1.60GHz) BIOS AMI BIOS. Press DEL to enter Chipset ATI Radeon Xpress 200 Memory 512MB 200pin DDR-333 SODIMM (2 memory slots. Max 2GB) Hard Drive 40GB Seagate ST9408114A CD Drive TSSTcorp DVD±RW TS-L532A Screen 15.4" widescreen TFT (native resolution 1280x800) Video Card ATI Radeon Xpress 200M IGP (up to 128MB shared) Sound Card Realtek AC'97 audio Network Card Realtek 8139/810X (onboard)
QCOM 802.11G Q802MKG (RT2560F) wireless LAN * Modem Agere Systems AC'97 (Actiontech/Qcom MD560LMI-2) PC Card None Ports 4x USB 2.0
1x LAN
1x Modem
1x Headphone
1x Microphone
1x S-Video (TV-Out)
1x VGA
1x Kensington Lock Touchpad Synaptics Touchpad Power Supply Lite-On PA-1700-02 Battery EM-G330L2 (11.1v 4400mAh) Dimensions 40 x 355 x 273 (HxWxD in mm) Weight 2.85kg Made By ECS 331
Feb 10, 2011 | Computers & Internet
I have intel D102GGC2 motherboard with ati radeon xpress 200.can i play movie smoothly in windos 7 32 bit? i have p4 processor.
ATI Radeon xpress 200 driver is installed automatically in windows 7, however if you face problem with the drivers you can download the latest drivers from the links below
Download ATI Radeon Xpress 200 WDM Integrated Driver v.10.2
Download ATI Radeon Xpress 200 Catalyst Software Suite v.10.2
if you require more assistance regarding this feel free to reply to this post
Regards-BA
Jan 13, 2011 | Intel D102GGC2 Motherboard
I HAVE PUT NEW AMD MOTHERBOARD. BUT I MADE SOME MISTAKE IN BIOS SETUP. NOW THE M/C IS NOT BOOTING
If the BIOS was not over written or flashed, when the system trys to boot press the F1 key or ther right ket to enter the BIOS and choose default setting and save and exit.
Sep 28, 2010 | AMD Sempron 2800, 2.0 GHz 2800+...
Lost passward
press f2 or delete during the boot process and enter BIOS you can change password from there be carefull
Jul 15, 2010 | SMS2800BOX3LB - AMD Mobile Sempron 2800...
Laptop will not start,
looks as though your hard drive is u/s Try and see if it is visible in the bios pages, if not replace it. Bios being, when you switch on you press f2, or ctl-alt.del or just del key. This puts you into the BIOS which tells the computer what it can and cannot do. The 1st page should have your hard drive listed, if not then replace it.
Jan 05, 2010 | Advent Netbook
ATI Radeon Express 200 series comapred to ATI Radeon 8500
Hi. The ATI Radeon Xpress 200 is better than the Radeon 8500.
Aug 19, 2009 | ATI Mobility RADEON Graphic Card
Sempron 2800 cpu speed
hey, here is the latest bios witch is required for your new sempron!
http://download.aopen.com.tw/userdownload_List.aspx?RecNo=9923&Model=vKM400Am-S
Dont foget to rate the solution as fixya! Thanks
If you need more assistance let me know, I'm here to help
Apr 02, 2008 | AOpen vKM400Am-S Motherboard
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
