My hp 1702 monitor is not working. It started last night to come on for a second and then turn off. It did this continually for 5 minutes and now the green light is on but there is no picture. If I click the on / off button I might get lucky and the picture stays on or it might just fritz off again quickly. Love to hear your thoughts on this. Thanks.
  • Anonymous Jan 12, 2009
    I tried the monitor on another laptop... same deal.. same problem
  • Anonymous Apr 09, 2009
    my monitor shuts off after like 30 minutes I turned on, already changed the thermical paste on the heat isolators and nothing
Those guys are right on how to troubleshoot this kind of monitors, about the bulges capacitors and cold solder terminal. Use a magnifying glass to check on cold solder lids. Concentrate on the coils and transistors lids
Posted on Jun 30, 2010
    Scholar:
  • 69 Answers
yeah so this happens alot and it is always one of three things.
1. the monior is shot
2. the video card component in the pc is done for
3. your cpu has a more serious problem.
i am leaning towards option one becase you say that the pc is on and you can sometimes see the screen and use the pc. Also another problem could be a short in the monitor cables themselves.
one good way to check out whats wrong is to hook up another monitor to the unit and see if everything is ok
i hope this helps.
Stellyx
Posted on Dec 08, 2008
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
After hooking up this monitor,the 1702 goes
Hi Don,
it sounds like your monitor's Capacitors have gone bad. This is very common. It is repairable, but the caps have to be removed and new ones resoldered on.
If you have soldering skills, not too tough of a job. If not, a shop will usually charge around $100 or so. You will have to weigh the cost vs a new monitor on this one.
Here is some more info for you on the Capacitor plague, that is quite common on monitors now.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 09, 2009 | HP L1702 17" LCD Monitor
HP 1702 Monitor comes on but immediately goes off.
There are five capacitors on the power board which have dried out and need replacement. A reputable repair shop should be able to fix this for around $50.00 including labor.
Mar 23, 2009 | Computers & Internet
HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
Jan 08, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP 1702 won't power up
http://mcmelectronics.com/browse/Capacitors/3829501
Sep 21, 2008 | HP L1702 17" LCD Monitor
The monitor brings a 10cm thick line after powering on
this type of problem is may be due to the magnetic appliances near by ur monitor such as speakers etc... try keeping the speakers away for some distance and then in the monitor there will be one menu just press that and then go to degauss and give degauss... your problem will be solved...
if problem persists then may be the tube is gone just visit the technician ... he may tell u that he must recharge the tube....
Feb 10, 2008 | HP L1702 17" LCD Monitor
Computers & Internet Logo
515 people viewed this question
David Payne
David Payne
