Question about Texas Instruments TI-30XA Calculator
How Do I use a square root to the 5th power? - Texas Instruments TI-30XA Calculator
  • 10,594 Answers
Type a number, click the button where it shows a carrot shape symbol ( ^ ), and click 5
Posted on Dec 08, 2008
Square root
looking at the buutons, it is at the far left, 5th down it says x2 put the number before it then click that button and then it should square
Jan 18, 2014 | Texas Instruments TI-84 Plus Calculator
How do I use my square root, cube and 5th powers on the calcalatar?
Use the y^x key just above the divide key. For example, to raise 2 to the 4th power, press 2 y^x 4 =
Nov 10, 2013 | Texas Instruments TI-30XA Calculator
Simplify the square root of the fifth root of 64q^8v^6
Square root equivalent to power 1/2
Fifth root equivalent to power 1/5
square root of fifth root (if argument of square root is positive) is equivalent to power 1/10
64^(1/10)*q^(4/5)*v^(3/5)
using 64=2^6 you get 2^(3/5)*q^(4/5)*v^(3/5)
Jul 13, 2013 | SoftMath Algebrator - Algebra Homework...
4 squre root 81
Take the fourth root. The square root, denoted by a 2 on top of the "root thing" or more commonly without a number at all, is the second root.
Usually the easiest way to calculate the fourth root is to calculate the square root of the square root. So in this case the fourth root of 81 is the square root of the square root of 81. The square root of 81 is 9, the square root of 9 is 3.
Apr 18, 2013 | Office Equipment & Supplies
I'm doing radicals I need to type an exponent into my calculator that goes before the square root not after. how do i do that (5) as an exponent square root of 32.....the answer is 2 but how do i type it...
Use the xth-root function to compute any root. It's the fifth entry on the MATH menu, which you can get by pressing the MATH key. The fourth entry on the same menu gives you the third root without needing the 3 to be specified.
For example, to compute the 5th root of 32, press 5 MATH 5 3 2 ENTER.
Oct 21, 2010 | Texas Instruments TI-83 Plus Calculator
How do i do a number 'to the power of 1/2 or 2/3? cheers Brad
Power 1/2 is the same as square root: You can use the square root key to the left of the square key.
Similarly power 1/3 is the cube root. You use the [SHIFT][Square root] key sequence.
Power 2/3 is the square of the cube root, or the cube root of the square.
More generally, you can use the universal power key, marked with X with a raised white rectangle. It is between X square and log.
Ex: Calculate 15^(2/3)
15 [X with raised rectangle] 2 [/] 3 [)] [=]; the result is 6.082
The last parenthesis closes the left parenthesis introduced by the calculator.
Alternatively you can use the cube root and the x-root selections available under the MATH menu.(selections 4 and 5)
Mar 14, 2010 | Casio FX-115ES Scientific Calculator
Square roots
One way is you get square root by raising to the (1/2) power. For example square root of 16 is
16^(1/2).
You can use this method to get the other "roots" as well e.g. 1/3, 1/4, etc.
Apr 02, 2009 | Texas Instruments TI-30XA Calculator
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Dec 01, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
174 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
